eBay Turbo Garbage?
Old Jul 21, 2014 | 04:06 PM
mdrouillard1983's Avatar
Default eBay Turbo Garbage?
So, I just checked my turbo for shaft play for kicks and its wiiggling; the damned thing is relatively loose and has been rubbing against the inside wall of the inlet as it spun. Oil was always provided to the turbo with a restrictor as well, so lack of lubrication couldn't of caused this. Anyone have similar experiences?
Just great, thank god I'm not too upset considering they sell for $200.00
I need some good recommendations for a new turbo, something of decent quality; a Garrett or something with an internal wastegate perhaps. But also won't break the bank.
Old Jul 21, 2014 | 04:09 PM
Freemananana's Avatar
Default Re: eBay Turbo Garbage?
What turbo manifold do you have?
What motor?
Modifications?
Exhaust?
Power goals?
Car goals?
Old Jul 21, 2014 | 04:10 PM
http://www.ebay.com/itm/88-00-Civic-EF-EG-EK-1-5L-1-6L-D15-D16-D16Y-SOHC-T3-T3-T4-T04E-Turbo-Charger-Kit-/171388486327?pt=Motors_Car_Truck_Parts_Accessories&hash=item27e78cc2b7&vxp=mtr
This is basically what I have, the exhaust manifold is the exact same one.
Old Jul 21, 2014 | 04:11 PM
What motor? D16A6 Block, D1yY8 Head MiniMe
Modifications? Eagle Rods, Vitara 75mm Pistons, 320CC Bosche OBD1 Injectors, P28 Chipped ECU, Adjustable FPR, Wahlbro 255LH Pump
Exhaust? 2.5" Exhaust with Magnaflow high flow cat
Power goals? 300HP
Car goals? Weekend/summer car, but decent power for reliability
See above for mods.
Old Jul 21, 2014 | 05:03 PM
Get a Garret T3/T4 .50 or .57 trim turbo. May be able to find it with the 5 bolt exhaust housing and use the same downpipe. If not, a simple conversion to 4 bolt or Vband would get you on track.
You'll probably want bigger injectors too. They look very small.
Find one of these:
http://www.go-autoworks-store.com/gat345tr.html
Used would save you some bucks.
BoostdK
Oct 24, 2009 07:57 AM
j-bird20
Dec 22, 2007 06:03 PM
FW_EJ8
Nov 28, 2007 08:42 PM
Radyjr
Jul 17, 2005 11:31 AM
