Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Civic - rough idle
Old Jul 20, 2014 | 07:22 PM
ohjonesio's Avatar
Default 2002 Civic - rough idle
2002 honda civic rough idle, does not respond to gas pedal but very intermittent, did find radiator slightly low, burped coolent system, runs better but still intermittent.
Old Jul 23, 2014 | 09:02 AM
jdmeg6118's Avatar
Default Re: 2002 Civic - rough idle
Tune up possibly?
Old Jul 28, 2014 | 07:31 PM
EF'GSRrr91's Avatar
cel on ?
Old Jul 29, 2014 | 10:35 PM
jermo's Avatar
Im with JDMEG, i had an EK that was running like dogsh*t and wouldnt stay started...i actually thought for a second the engine might be blown...decided to throw on some plug wires as a quick test and BAM it ran perfectly, so bizarre how something so little could make a car run so bad. Anyway i'd start small and check spark plugs, inspect the ignition coils, check air filter and so forth...
Old Aug 1, 2014 | 08:50 AM
03blkevo's Avatar
Another thing you can check is the Idle air sensor, if that is shot, then the car wont hold an standard idle. you can Try putting it in neutral and bring to the rpms up to 5k and let go of the pedal, if it drops, and almost stalls that might be a good place to look as well.
Old Aug 2, 2014 | 02:25 PM
lowlife9's Avatar
yeah first try cleaning the IACV,throttle body, and EGR valve which is free if you have a bottle of carb cleaner lying around. read this http://www.civicforums.com/forums/11...e-up-mods.html
Old Aug 15, 2014 | 05:41 PM
2005CivicVP's Avatar
I had a rough idle at 149k so I installed new plugs and adjusted the valves and now the valve ticking noise is gone and it idles fine. I also replaved the valve cover gasket and spark plug tube grommets because oil got through to the plug base and could have been affecting the ground path and robbing my plugs from so of the spark.
reureubear
Nov 22, 2015 03:34 PM
Dragon760
Mar 13, 2014 04:15 PM
effun
Mar 19, 2011 02:59 PM
stevescivic
Dec 8, 2008 09:24 AM
ArchAngel Sabastian
Sep 11, 2002 09:29 PM
