Mechanic removed thermostat
Old Jul 19, 2014 | 09:23 PM
cesarjr's Avatar
Default Mechanic removed thermostat
My mechanic decided to let the thermostat go on my car cause of random overheating. For some reason he said this was the best decision.
I'm planning to replace it though.
My question is should I keep driving with no thermostat or put one back in ASAP?
Old Jul 21, 2014 | 07:02 AM
Camhaas's Avatar
Default Re: Newbie Question
I don't have on on my car and its boosted runs fine. Where was yours at and what car and motor
Old Jul 21, 2014 | 08:36 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
If it is a stock daily driver it is HIGHLY recommended to have a thermostat installed. This is especially important in colder climates.
Old Jul 21, 2014 | 12:35 PM
spAdam's Avatar
Loved
Community Favorite
Your mechanic sucks. Put a new thermostat in it.
Old Jul 21, 2014 | 01:49 PM
spoolymcgee's Avatar
LOL the best part about it, is their not a PIA to replace nor expensive.
Old Jul 21, 2014 | 03:16 PM
Spunkster's Avatar
Get a real mechanic.
Old Jul 21, 2014 | 06:37 PM
russian239's Avatar
Not sure if it's the same way with Honda, but with a Mazda engine the problem with running without a thermostat is that you end up not getting the engine warm enough. First of all it's just not the temperature the engine was designed for, and then you might end up constantly running with warm-up enrichment.
Old Jul 22, 2014 | 01:47 AM
spAdam's Avatar
Loved
Community Favorite
That's any water cooled engine. The point of the thermostat is to help the engine reach a temperature and stay there by regulating coolant flow.
Take it out and you get whatever you get, most likely the engine doesn't run right end you tuner hates you too.
Old Jul 22, 2014 | 08:37 AM
veks's Avatar
post up the name of the shop so other people don't go to this person.
Old Jul 22, 2014 | 02:42 PM
slynch0210's Avatar
Absolutely post the shop you went to, why he would just leave it out than tell you what the deal was is weird, like said above, if its your DD i would install asap, if its a track car i could see it not effecting it much.
Old Jul 22, 2014 | 02:47 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: Mechanic removed thermostat
thermostat only sets the minimum temp your engine will run at, thats really important as closed loop and everything else is based on it reaching that minimum temp
Old Jul 25, 2014 | 06:55 PM
daxr's Avatar
The engine will run cold, get bad mileage, and gum up the valves and combustion chamber. I know because I tried that years ago on a car when I was too broke to buy a t-stat. I pulled the stuck one out and drilled a hole in the plate, hoping it would stop overheating. What happened was the engine would take a half hour to get to operating temperature, during which time it ran like crap, got terrible mileage, and really gummed up the combustion chambers. Eventually I got a persistent misfire and had to pull the plugs out and soak them in solvent and run a bunch of cleaner through the engine.
bikewithnoname
15
Apr 2, 2009 11:34 AM
litterbox
Mar 16, 2009 06:50 AM
b20integrapower
Jan 1, 2006 09:47 PM
iH8RICERZ
Feb 3, 2004 12:59 PM
NewYorkTypeR
Jun 15, 2001 09:09 PM
