limp mode ?!?
Old Jul 19, 2014 | 08:03 AM
toolbox21's Avatar
Default limp mode ?!?
Just put a fresh d16z6 swap in my buddys 95 ex, starts and runs perfect with no codes, except it wont rev past 5500, im assuming its in limp mode, I've changed the ecu with a known good stock p28, and changed the vss, still same thing. Any suggestions ? Im also in the mix of getting a hold of another friends distributor to see check that. Like I said no codes.
Old Jul 19, 2014 | 09:20 AM
grumblemarc's Avatar
The Grumpiest
Default Re: limp mode ?!?
Make sure everything is connected and connected properly.
Old Jul 19, 2014 | 09:22 AM
toolbox21's Avatar
Triple checked all wiring on harness, its good to go.
Old Jul 19, 2014 | 12:49 PM
andoxviii's Avatar
This may sound stupid but are you sure your tachometer is accurate? Easy way to tell is if you hear VTEC engage or not. I was about to recommend you buy an ELM 327 on eBay for $8 to verify but that wouldn't work because you are OBD1. Only way to verify would be to swap in another cluster or temporarily hook up an aftermarket tachometer.
I find it strange that your car would be in a limp mode without a check engine light.
Old Jul 19, 2014 | 01:02 PM
shotoutacc0rd's Avatar
Are you sure there's no codes? Have you checked the CEL to ensure it works proper?
Old Jul 19, 2014 | 03:04 PM
tony_2018's Avatar
Fish Twig
Distributor could be the issue. Ecu is not reading a signal properly.
Jeopardy_02
19
Jan 18, 2020 10:24 AM
99 4dr sohc-T
Mar 4, 2009 05:19 PM
slowcrxsib16
Jan 17, 2007 03:41 AM
jdmazm
Apr 24, 2005 04:35 PM
Raggedyman
Jun 6, 2004 01:18 PM
