L3 Main Input Bearing Check??
Old Jul 19, 2014 | 12:13 AM
journeyquest's Avatar
Default L3 Main Input Bearing Check??
Any way to check the main input bearing on an 88-91 5 speed transmission without splitting the case. The trans is out of the car. Thanks.
Old Jul 19, 2014 | 07:12 AM
99teggsr's Avatar
Default Re: L3 Main Input Bearing Check??
I have heard you can put an axle in it and wiggle it around, if its loose then the ISB is on its way out.
Old Jul 19, 2014 | 11:34 AM
94EG8's Avatar
Seagull Management
Originally Posted by journeyquest
Any way to check the main input bearing on an 88-91 5 speed transmission without splitting the case?
Nope. Well if you can wiggle the input shaft up and down it's beyond bad, but even if there isn't any play it can still be bad.
Old Jul 19, 2014 | 12:50 PM
No play side to side or in and out. The shaft turns freely. I know these things are known for their great bearings and forks. One guy wants 300 labor to replace bearing w trans already out of car. Seems a bit steep to me.
JDM_addict
Transmission & Drivetrain
May 31, 2012 07:06 AM
ekhaze
Mar 25, 2011 01:57 PM
phong3992
Sep 29, 2010 06:01 AM
prelude182
Aug 3, 2009 05:53 PM
del_slow420
Sep 24, 2007 06:32 AM
