Blown head gasket ?
Hello, I've got a 1994 Honda DelSol with a B16A2, I recently changed the engine oil, spark plugs and oil filter and I've noticed that every 4 days I need to top up the coolant, here are some things I've also found:
- Opened up the oil cap and theres the milky substance on the inside but in the dipstick the oil is fine
- The car has never over-heated on me
- The radiator was replaced at the beginning of the year
- Blows white smoke and clear liquid from the exhaust only when it isn't fully warmed
- There is also black ash like marks under the exhaust
If it helps the weather here has been below 10°C (50°F)
Does anyone have any suggestions? or is it a blown head gasket?
I've also got some images if it helps:
Oil Cap:
Dip Stick:
Ash-Like Substance:
Exhaust Fumes (See Liquid Spraying):
Oil Cap:
Dip Stick:
Ash-Like Substance:
Holy **** that's a lot of stuff spewing out of your exhaust.
Do a block test to confirm, but your head gasket is likely blown. When everything heats up, the metal swells and tries to fill in where the head gasket is damaged, but that's not good for your car.
Thanks for all the suggestions, spewing that it's the head gasket but I'll double check with the block and compression tester
I was told that there is a small chance that it can be condensation, but I'll check anyways, thanks again
As far as I can see in the pic, the oil on the dipstick looks normal, it's just the top of the oil cap that has the "look".
Question about your exhaust, is that on initial start up or does it do that after a 20 minute drive?
If it's still doing it after a solid drive, than I may be concerned but if it's only on initial start up after sitting for a few hours or more and goes away once warm, you are probably fine.
Like NotARacist said, a compression test and a block test will be a lot more definitive on whether your HG is toast.
It only does it on start up, when I leave it in the drive way to warm up, after that it's normal
Yeah I'll probably just get the tests done first before I start assuming anything
If it turns out to be the head gasket I'll just take it to my mechanic and get him to do what he thinks needs to be done
Thanks again
Thanks again
Something as simple as a leaky valve cover gasket could potentially let in moist air to condense on interior surfaces of the head, most of it gets washed away and dealt with by the oil additives to combat moisture except that lovely oil cap.
I don't believe that to be irrefutable evidence of a bad head gasket, unlike certain results of a compression test or the lovely yellow colour of a block test.
There are many areas to lose coolant, and the head gasket is only one of them.
JdmJah
16
Feb 19, 2013 06:42 PM
MikesBB4
Apr 9, 2012 10:17 PM
taimysho0
Jul 27, 2007 09:40 PM
