Y8 bogs
Old Jul 17, 2014 | 06:00 PM
MabChiLee's Avatar
Default Y8 bogs
So my car bogs around 2k-3k rpm when it is warned up or drive for a while. I've changed spark plugs and even my distributor o-ring cause it was leaking. Could it be some fuel problems or is it some wiring problems? I did google research and they only give generals. Any one know any specific?
Update!!: so when If I clearly let go of gas first then shift my car runs fine but if I do like a quick shift where throttle has just stopped then shift car bogs from 2k-2.5k rpm. Similar to anyone's problem?
Old Jul 17, 2014 | 06:09 PM
MabChiLee's Avatar
Default Re: Y8 bogs
Mostly happen 2nd n 3rd gear btw
Old Jul 19, 2014 | 01:01 PM
MabChiLee's Avatar
Default Re: Y8 bogs
Anyone? *bump*
Old Jul 19, 2014 | 01:22 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Y8 bogs
Check your ignition timing. When was your last FULL tune-up?
Old Jul 19, 2014 | 04:27 PM
MabChiLee's Avatar
Default Re: Y8 bogs
When you say ignition timing you mean timing belt? And my car is stock so I never or recall a full tune up.
Old Jul 19, 2014 | 04:35 PM
andoxviii's Avatar
Default Re: Y8 bogs
No. That is cam timing or "mechanical timing".
You need to change the spark plugs, ignition wires, distributor cap and rotor, air filter (change or clean) and fuel filter. As a minimum.
Old Jul 19, 2014 | 04:39 PM
delsolintegra's Avatar
Default Re: Y8 bogs
I had the same problem with my 93 del sol si D16z6. After the tuneup it still wasn't right so I replaced my throttle position sensor (TPS). Had the original one in there I figured after 21 years it might need to be changed .
There's a good write up on it. If I find it I'll link it.
Old Jul 19, 2014 | 04:40 PM
Default Re: Y8 bogs
https://honda-tech.com/forums/showth...7986&styleid=2
Here it is.
Old Jul 19, 2014 | 08:31 PM
MabChiLee's Avatar
Default Re: Y8 bogs
I see. So pretty much change the whole distributor? With wires? Would fuel injectors be some sort of problems too?
Old Jul 19, 2014 | 08:32 PM
MabChiLee's Avatar
Default Re: Y8 bogs
Originally Posted by delsolintegra
Thanks man, that might be my last resort too. I kinda wanted to do simple stuff to fix it first cause It is my daily driven car.
Old Jul 22, 2014 | 06:46 AM
MabChiLee's Avatar
Default Re: Y8 bogs
Bump*
Old Jul 22, 2014 | 06:52 AM
andoxviii's Avatar
Default Re: Y8 bogs
No, not the whole distributor. That is costly and pointless unless your distributor isn't working.
A tune-up involves replacing just the distributor's cap and rotor (among the other things I listed above.
Old Jul 22, 2014 | 06:55 AM
MabChiLee's Avatar
Default Re: Y8 bogs
Can the o2 sensor be the cause of it too? Or would it need to throw a CEL?
jdm36
27
May 3, 2011 11:31 AM
rotascircuit
Mar 22, 2008 11:29 PM
ApolloSpeed
14
Aug 19, 2005 09:12 AM
fxrob
Dec 28, 2003 08:21 AM
wildstallion
Oct 1, 2002 05:55 PM
