ECU question
Old Oct 31, 2002 | 07:02 AM
EF_LSVtec's Avatar
Default ECU question
Didnt really notice it before or had any idea...does the ecu really blink constantly? I had my check engine light go off this morning but when I checked for codes a few minutes later...turned the ignition on then the ECU light just blinked every 3 or 4 seconds...I stopped counting after 45, haha..I hope my ecu didnt make a fool out of me for actually counting that high.
Old Oct 31, 2002 | 07:06 AM
EP3_05's Avatar
Default Re: ECU question (EF_LSVtec)
It usually only will blink a couple of times during startup while the cel is on if there are no codes. Sounds like it might be a code 1. Does it blink once and then pause and then blink again?
Old Oct 31, 2002 | 07:15 AM
Trinity's Avatar
Default Re: ECU question (91civic)
it shouldn't constantly blink no. like the person above me said it blinks a couple times when you first turn the car on but won't keep blinking
EF_LSVtec's Avatar
Its like a constant intermitent blink...looks like an alarm led light of some sort that just blinks constantly on your dash every couple of seconds...
Old Oct 31, 2002 | 07:17 AM
EP3_05's Avatar
Sounds like code #1 to me. It is the oxygen sensor. If it is the stock one that has tons of miles on it it probably needs to be replaced.
Old Oct 31, 2002 | 07:18 AM
Trinity's Avatar
and if it needs to be replaced just go to a junkyard and pull one off.
Old Oct 31, 2002 | 07:38 AM
EF_LSVtec's Avatar
Default Re: ECU question (Trinity)
I drove down to LA and back last Sunday (800 miles) used a chipped ECU...Anyway, i posted a thread about the motor hesitating under 4000 rpm after flooring it a few times...probably ran too rich and covered the O2 with shiit. I only used the chipped ECU because I'm getting a VSS code on the stock one...I'm fixing that tonight but thats another story...Thanks folks
efjones9
16
Jun 10, 2009 08:33 AM
Guru Designs
Jun 13, 2005 05:06 PM
stockintegra
Mar 27, 2004 02:13 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
RedRacerCivic
Dec 6, 2001 11:45 AM
