problem with b16a swap
Old Jul 13, 2014 | 04:10 PM
jeffinlimbo's Avatar
Default problem with b16a swap
Hey guys not sure if this has been covered. I did a jdm b16a swap into an 89' honda crx si with a 37820-p30-000 ecu. I also have the rywire obd0-obd1 jumper harness. I had it working for a little bit then the fuel pump stopped priming when I turned the key to on position. I replaced the ecu with another one like it and then I was having a voltage issue. When I would put a load on the engine when driving the voltage would drop until I reached about 45 mph. As long as I was driving the voltage was fine, but once I slowed down the voltage would drop again. I put another ecu in and the voltage was fine and everything worked for about 3 days than my rpms would drop almost stalling the car. This happened a couple of times and then it went away, but now my rpms idle at 1000-1100 rpms when the car is all warmed up. I've already replaced the iacv, fitv, reman alternator, new battery and vacuum hoses. I put another ecu in the car and it idled fine, but the voltage issue was back again. I can't figure this out and was hoping ya'll might be able to. I was wondering if the rywire harness could be messed up maybe. the fuel pump is a walbro 255 high flow also.
Old Jul 14, 2014 | 04:59 AM
Freemananana's Avatar
Default Re: problem with b16a swap
Main relay possibly. That or you are getting some sort of ELD issue. Check your grounds. Seems like a weird issue all together. The idle could be a vacuum leak if you replaced everything already. Have you bleed the coolant system?
Old Jul 14, 2014 | 05:12 AM
F22Master's Avatar
Have you tried setting the idle by the method described in the FSM?
Old Jul 14, 2014 | 09:11 AM
yes I tried another main relay. Also changed out the fuse box with eld. Bleed coolant lines and set the idle according to the manual.
Old Jul 14, 2014 | 09:14 AM
Have you checked the grounds and the wires that lead to them? Bad ground contact or worn wires will lead to unusual voltage drops.
simplejackk
15
Jan 22, 2012 10:14 PM
mynameizstitch
Feb 19, 2010 08:57 AM
iCollectStraws
Feb 12, 2010 09:42 AM
StocknSlow
Mar 7, 2008 02:28 AM
s0flyy56
May 23, 2007 06:52 PM
