Engine Help!
I've been looking for a while now and I can't seem to find specs about my engine. Maybe someone can point in the right direction for me... I have a 1989 Acura Integra 4-1590 1.6L DOHC. If someone could fill me in on some information on this engine, that would be great!
Thanks!
EDIT: I did more research and I think the code is either D16A1 or D16A3... Can anyone verify?
Thanks!
Probably the D16A1. The A3 is Australian.
1988–1989: USDM Blacktop
Compression: 9.5: 1
Power: 118 hp (88 kW; 120 PS) at 6,500 rpm
Torque: 14.2 kg·m (139 N·m; 103 lb·ft) at 5,500 rpm
Piston Code: P29
ECU Code: PG7, Electronic Advance Distributor
Compression: 9.5: 1
Piston Code: P29
All I know is that the engine has been rebuilt. I'm not sure exactly what they did to it before I bought it. Also, I was looking at this sheet right here to help figure it out. https://docs.google.com/spreadsheet/...=sharing#gid=0
