Help
Old Jul 8, 2014 | 07:58 PM
Eddieem1ef2's Avatar
Default Help
So I have a fully built b16 head and a fully built b20 block, when I start it up
It smokes and it smokes a little bit when I am driving around, is it that the rings need to fully seal, or do I need to do more work? Block has 300 miles on it
Old Jul 8, 2014 | 10:09 PM
UncleD's Avatar
Default Re: Help
"Fully built" huh?
Bad headgasket? Bad valve seals? Compression test?
Old Jul 8, 2014 | 10:50 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: Help
Whats fully built? If its a fresh build, it should on a dyno getting abused so the rings will seat right. Driving it around wont much since you cant beat on it.
Old Jul 9, 2014 | 12:34 AM
Default Re: Help
Rods pistons bearings seals cams valves retainers everything everything has been replaced and it was due to having the same problem with my b16 block but the smoke was worse, It smokes one good tine when it starts up avd when it's running there's very little coming our but it still is, what should I do, do I wait x amount of miles for it so the rings ca sit, or do I have my dude take it apart and figure out how to make it stop
Old Jul 9, 2014 | 12:48 AM
m4xwellmurd3r's Avatar
hate to break it to ya dude but your rings arent gonna seat properly if they havent already
80% of the ring seating occurs within the first 20 miles.
Old Jul 9, 2014 | 05:10 PM
soaringchimp's Avatar
Default Re: Help
What tune is on the ECU?
You could just be very rich.
Is it using oil?
Any changes to fuel system?
I've also seen engines in which the ring gaps were not oriented properly around the piston when it went into the block smoke like that.
jdmboy94
Jun 7, 2009 08:20 AM
Sassafrass
14
Aug 15, 2006 11:51 PM
toofast4u752
May 8, 2006 04:32 PM
ghettochild
Dec 11, 2004 04:17 AM
jerseydevil
Apr 4, 2004 07:29 AM
