Freshly Built ls Problem?
Old Jun 6, 2009 | 11:43 PM
jdmboy94's Avatar
Default Freshly Built ls Problem?
well i have a built ls, full crower valvetrain, valves, retainers,springs, crower 404 cams, mild port and polished head, slight over bore on block to 81.5mm with itr pistons, knife edged crank and full exaust. well i dont think one of the piston rings seated properly? it is burning oil and i there is some blow by. all gaskets and piston rings are new. the motor has about 600 miles on it. i am suppose to get it tuned this thursday. will the ring seat by it self? or what? im not sure what to do. thanks
Old Jun 7, 2009 | 12:07 AM
jasoncanseeoh's Avatar
Default Re: Freshly Built ls Problem?
well, obviously there's a leak somewhere, right???
Old Jun 7, 2009 | 12:10 AM
jdmboy94's Avatar
yea. nothing leaking from under the car, head gasket is good. so im wondering if one or more of the rings havent seated.
Old Jun 7, 2009 | 01:29 AM
stevenDAtegra's Avatar
Are the valve seals new as well? It already has a lot of miles on it, but try to put a load on the engine and bog it in 3rd. It may be too late if the rings didn't seat right but it's worth a shot
Old Jun 7, 2009 | 01:37 AM
Ruben19's Avatar
do a quick compression test. how much oil are you burning?
Old Jun 7, 2009 | 01:43 AM
jdmboy94's Avatar
yea the seals are new, everthing thing was replaced when built. umm its not that much. but it needs a tune bad, im getting it tuned thursday. it is running really rich right now.
Old Jun 7, 2009 | 08:20 AM
gsnickets's Avatar
at 600 miles they should have seated properly by now if not you probably have a problem.
Eddieem1ef2
Jul 9, 2014 05:10 PM
ghettochild
Dec 11, 2004 04:17 AM
sleepin91teg
Nov 9, 2004 12:25 AM
SCsol
Feb 21, 2002 09:29 AM
Jared
Sep 7, 2001 10:55 PM
