Help with my 1990 civic.
Old Jul 6, 2014 | 06:28 PM
Danglenn12's Avatar
Default Help with my 1990 civic.
My timing belt broke yesterday on my car I was wondering if my motor is toast? If not is it ok to buy a kragen timing belt or an OE belt? Thanks Dan
Old Jul 6, 2014 | 10:19 PM
holmesnmanny's Avatar
Default Re: Help with my 1990 civic.
Normally there is engine damage. You will need to get another belt on it and do a compression test to see if there is any damage.
Old Jul 7, 2014 | 05:38 PM
daxr's Avatar
You could also pop the valve cover off. If a valve is bent it will be stuck partway down, and there will be a noticeable gap under the cam lobes of the problem valves. You also wouldn't get very far with a compression check (and you'd have to do the timing belt first) if there's damage.
On that engine I think you have about a 50/50 chance, which is much better than most.
Old Jul 7, 2014 | 06:06 PM
grumblemarc's Avatar
The Grumpiest
Even though these are interference engines you have a good chance of there being no damage. But you're going to have to either pull the valve cover, as mentioned above, of the head.
Old Jul 14, 2014 | 04:49 AM
Danglenn12's Avatar
Thank you guys for the help I'm going to go buy a timing belt today and take off the valve cover this weekend. If they are bent is it easier to just buy a new head?
Dlarsson112
Engine Machining & Assembly
Jan 22, 2019 04:38 AM
ev94eg
Dec 10, 2012 05:43 PM
bobbed shadow
Honda Civic (2001 - 2005)
Oct 13, 2011 05:24 PM
bvcrv
Jan 16, 2010 05:46 PM
froggysquasher
Aug 26, 2004 05:18 PM
