Need help with h22 Lude
Old Jul 5, 2014 | 10:29 PM
Criscortezano's Avatar
Default Need help with h22 Lude
Hi I do Not know what to do! I have a 95 prelude srv with 190xxx miles with simple boltons, recently is started idling weird and jumping rpms and almost as if it wants to turn off. It also has a popping noise coming out of the exhaust like every 5 or 10 sec. What's wrong
Old Jul 5, 2014 | 11:13 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: Need help with h22 Lude
did it jump a tooth?
Old Jul 6, 2014 | 07:49 AM
I'm not sure? But what is that popping noise from ?
Old Jul 6, 2014 | 08:12 AM
1991_crxsi's Avatar
Popping noise could be from bad timing. Check your mechanical timing, timing belt, and timing belt automatic tensioner (these things wear out over time and can cause you some major problems.) I think 2LEM1 has a good suggestion.
Just put the engine at TDC and check your camshaft timing marks. If the timing marks are off then that means you jumped a tooth. That means you need to replace your timing belt (unless the timing belt is very new and is undamaged... but I would just replace it anyway), timing belt tensioner (Kaizenspeed makes a manual one that will never fail so just get that one...), and all the usual stuff that goes along with that job.
RandyOo
Dec 26, 2013 02:35 PM
5thGeneration
Nov 19, 2007 02:19 PM
JDMoMo
Dec 29, 2005 04:45 PM
ka0s187
Dec 14, 2005 12:25 PM
Next GenRacing
Dec 13, 2005 05:52 PM
