Need help with h23a swap on my eg
Old Jul 5, 2014 | 12:41 PM
Moreliano09's Avatar
Default Need help with h23a swap on my eg
I'm doing an h23a swap on my eg does anyone know what intake manifold and harness I need , I just moved to Indianapolis and I have very little knowledge of any good shops here, so I'm doing it myself, any information would be appreciated greatly,
Old Jul 5, 2014 | 12:47 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Need help with h23a swap on my eg
Er. I'm going to go out on a limb here but, the H23 manifold?
I have a question; did you read up on any resources before you tried doing the swap? I mean, it's been done successfully with plenty of guides, parts lists, etc. so I'm kinda not understanding why you're coming up short on information.
Like this link for instance.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A%2A%2Aokay-lets-cut-down-repeated-qs-about-certain-swaps-post-links-here%2A%2A%2A-650230/
Old Jul 5, 2014 | 12:50 PM
The Grumpiest
Here's another.
http://www.clubcivic.com/board/showthread.php?t=163290
Old Jul 5, 2014 | 12:52 PM
The Grumpiest
And another one.
https://honda-tech.com/forums/hybrid-engine-swaps-18/eg-h23-swap-help-3050302/
Old Jul 5, 2014 | 01:00 PM
The Grumpiest
And this one because I see you mentioned H2b
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A%2Aofficial-h2b-discussion-thread-%2A%2A-1638988/
Old Jul 5, 2014 | 01:01 PM
The Grumpiest
And another H2B resource.
https://honda-tech.com/forums/hybrid-engine-swaps-18/h2b-f2b-faq-1998426/
Old Jul 5, 2014 | 10:02 PM
TracerAcer2.2L's Avatar
Anti-GDD White Knight Simp
Hahahaha
Old Jul 6, 2014 | 12:37 AM
https://honda-tech.com/forums/showthread.php?t=650230
Thanks for the links, the information was extremely helpful, I have done extensive reading on the subject and have most of the parts I need, yet I've read tons of contradicting info on the intake manifold some say the h23a can be used most say they can't that's why I asked. But big thanks man I found tons of useful info in the links
Old Jul 7, 2014 | 04:19 AM
HiProfile's Avatar
If it's the JDM H23A dohc vtec engine, any H22 manifold or K20 adapter plate will work. If it's the USDM non-vtec H23A1 then you're stuck with the H23A1 manifold. The H23A1's upper plenum & IAB plate are identical to the H22 version, but the lower section has a different bolt pattern on the head.
Old Jul 7, 2014 | 08:34 PM
Thanks it's a vtec, h23a I herd the h22 works but I think ima go aftermarket instead, might as well if I'm going to need to buy a manifold
Bmocc
Dec 7, 2013 09:12 PM
area608EG
Mar 3, 2009 08:59 AM
japhonda
Jun 28, 2005 05:58 PM
hbkxtbone
Sep 23, 2004 10:09 AM
jdmitrhatch
May 20, 2004 07:46 AM
