93 del sol/b18b1 swap - codes 7, 21, 41
Old Jul 2, 2014 | 04:40 PM
Cuda 426's Avatar
Icon2 93 del sol/b18b1 swap - codes 7, 21, 41
hey guys new to the forum and looking for help. (the usual) haha. I have a 93 del sol (obd1) and I am putting in a b18b1. everything is done and hooked up but nothing is working. I am running the stock chassis harness with a p75 ecu and a 94 integra engine harness. when I got in to fire it up I noticed that none of my dash lights came on at all when I turned the key. when I put the clutch in to start the car and turn the key to start all that kicks on it my rad fan. I cant even hear my fuel pump prime. im hoping that someone on her has some advice for me cause I am at a loss other than my ecu being fried. and I have already triedm using the harness off the z6 that was in the car. had the same problems. thank you.
Turns out I missed a ground. Now I'm having another problem, car starts and idles fine but bogs out if I step on the gas and won't rev above 3000rpm. I'm getting codes 7 (tps) which is a brand new tps. Code 21 (vtec) which is wierd cause my ecu is a p75. And code 41 which is an o2 sensor cause I don't have one. Anyone have any ideas?
Last edited by Former User; Jul 4, 2014 at 08:56 AM. Reason: Updated CEL code information added to first post
Old Jul 2, 2014 | 06:44 PM
stupidhard's Avatar
Default Re: 93 del sol b18b1
check all your ground points and make sure you're getting voltage on the wire harness by checking with a volt meter. go over every visible inch of the engine and chassis harness to make sure you didn't cut or mangle anything inadvertently. check all main fuses and relays.
there is a process to diagnose nearly anything. start at point "A" (battery) and work your way back (ignition switch). that's a lot of ground to cover, factory service manuals (FSM) are available on line in PDF form that include wiring diagrams. even with a swap, you should be able to find all the critical points to check. download diagrams for both your car and the donor car, sit down and study, eat something, then go to work. its gotta be something simple and silly, that swap should be a drop in with no electrical puzzles to solve.
good luck.
-chris
p.s. check out the FAQ also.
Old Jul 3, 2014 | 08:04 PM
Former User's Avatar
Do the headlights, hazard lights, or horn work?
Start by checking the fuses, like 31, 24, and 18.
Old Jul 3, 2014 | 10:33 PM
Cuda 426's Avatar
Thank you for the help turns out I missed a ground. Now I'm having another problem, car starts and idles fine but bogs out if I step on the gas and won't rev above 3000rpm. I'm getting codes 7 (tps) which is a brand new tps. Code 21 (vtec) which is wierd cause my ecu is a p75. And code 41 which is an o2 sensor cause I don't have one. Anyone have any ideas?
Old Jul 3, 2014 | 10:56 PM
eghatch9295's Avatar
Stancetard Hate Monger
re count the cel flashes, vtec is impossible to have thrown on a non vtec ecu
Old Jul 3, 2014 | 11:04 PM
Cuda 426's Avatar
I've counted the cell flashes about 18 times today. It's always the same codes.
Old Jul 3, 2014 | 11:49 PM
is the ecu chipped?
Old Jul 4, 2014 | 01:48 AM
Cuda 426's Avatar
Yes not sure with what though. It's an older chip.
Old Jul 4, 2014 | 05:38 AM
Reset the ECU to see whether all codes repeat.
Old Jul 4, 2014 | 08:12 AM
Cuda 426's Avatar
I did that a couple times yesterday and it keeps throwing those codes. I even took the chip out but that didn't help at all, if anything made it worse. and without the chip in it it wouldn't give me any codes, the engine light just stayed on. jumping the plug wouldn't give me cell flashes. plugged the chip back in and as soon as I hooked it up again it would flash.
Old Jul 4, 2014 | 08:43 AM
Default Re: 93 del sol/b18b1 swap - codes 7, 21, 41
Why is your P75 ECU chipped?
Have you checked for swapped sensor connectors by matching connector wire colors to each sensor?
Old Jul 4, 2014 | 09:32 AM
kind of sounds like the ecu might be causing all/some of this. do you have a p06 available to you to try out?
Old Jul 4, 2014 | 09:36 AM
Cuda 426's Avatar
yes I went over the whole harness and there are a lot of colors that don't match up on my shock towers but the wrong colors go to the right sensors for the colors on the chassis harness. I think I am maybe having trouble because I don't have a map sensor. the colors for the tps are green, red/blue, and yellow/blue I believe? anyways, when I plug those wires into the tps the car wont start (fires and shuts off) but if I switch the plug (plug in the map sensor wires to the tps) and leave the tps wires unplugged. the car will start up and run but then it gives me the problems im having. and I think my ecu might be going into limp mode. that's why its not revving above 3000
Old Jul 4, 2014 | 09:44 AM
Cuda 426's Avatar
and no I don't have any extra ecu's around at all.
Old Jul 4, 2014 | 09:50 AM
You have a wiring nightmare. Unplug the battery and properly sort out the wiring before you fry the wires and blow the ECU and other components.
http://www.phearable.net/information/tech-area.html
So why no MAP sensor CEL code?
You are way over your head for this project. Pay a professional.
Old Jul 4, 2014 | 11:23 AM
Cuda 426's Avatar
im not getting a map cel code because its plugged into my tps. only way it will run. that's why its throwing a tps code. and ive already gone over the ecu pinouts. it all checks out. and as for the chip I bought the ecu with a chip.
Old Jul 4, 2014 | 11:31 AM
Wow. You need to walk away from this car and seek professional car help. All you are doing is damaging the car.
Old Jul 4, 2014 | 12:23 PM
yes. op, do the following: go to the junkyard, pull a 92-95 civic non vtec engine harness, and swap that on for the hacked up one you've got. id snag a p06 while there as well. hell, i saw a couple obd-1 integras at my local yard, if you want to pay their $40 or so and whatever shipping is ill get one for you.
Old Jul 4, 2014 | 01:18 PM
Cuda 426's Avatar
that's the weird thing though my harness was out of a stock 94 integra and I tried a harness out of my friends 94 civic as well. im just gonna get a map sensor, plug it in and see if it works. thanks for the offer though I really appreciate the help.
Old Jul 5, 2014 | 05:46 AM
78F350's Avatar
The MAP sensor will not solve the issue of the VTEC (code 21). You are probably going to need a different ECU. If it is chipped for VTEC and tuned, it will not work well for a stock B18B1 with or without a good MAP sensor. Can you post a pic of your ECU with the top cover off, just so we can verify what you have?
Old Jul 5, 2014 | 08:24 AM
Cuda 426's Avatar
So I got a map sensor in and It runs better now but I'm having an issue below 2000rpm. It struggles to keep running and wants to die if I don't give it a bit of gas. When it does idle on its own it sits at 500rpm and sounds like a lawnmower. And I can't post pictures but I'll look at the circuit board and compare it to what it's supposed to look like. I know you can convert ecu's to vtec
Old Jul 5, 2014 | 08:26 AM
Cuda 426's Avatar
Oh and the car now revs just fine when it's above 2000rpm. And it only bogs below 2000rpm now
Mikejo
Dec 28, 2016 07:47 PM
grinch559
May 23, 2012 07:05 PM
Cain93delsol
Jan 16, 2012 10:58 AM
