94 civic hatch with lsvtec - Vtec engages at startup
Alright, 94 civic hatch with lsvtec. B16a head b18a1 block. I have an led hooked in line with the Vtec for trouble shooting purposes. When you start the car, the light comes on and the car is hard to keep idle unless you give it some gas til the light shuts off then the cars fine. Tuned on Neptune but did this before the tune. It's not every time but it's enough to annoy me at this point. Any suggestions on what to look for? I noticed this happening changing the head gasket. It's really the only thing I can think of that has been done.
Re: Vtec engages at startup
I've had the led wired in since I've owned the car. So roughly a year and a half now. This is just a more recent problem.
Honestly don't know. It just started happening after a head gasket change. Not immediately after but that's the only thing that's been done before it started happening. I'm stumped.
Changed oil, cleaned solenoid screen. The basic vtec engagement problem stuff. But, vtec works which is the problem
Posted from Honda-tech.com App for Android
Be about that Toda killer cam life doe .
on a serious note can you try a different ECU ? or see if something is grounding out when it shouldn't be
Yeah I can try another ecu, that's no a problem. The grounding out issue though, wouldn't it stay engaged all the time?
Bumping this because I'm still facing the issue.
Now the car has a low mileage gsr and engine still seems to engage vtec at start up, randomly. Car will bog but can remedy by holding the gas until it stops. Still not doing this all the time but enough for me to bump the thread. But, vtec does not engage at all, only at random start ups. The only thing I can think of is that I'm tuned on Neptune and prior to this I believe I was tuned on crome and never had a problem.
Re: 94 civic hatch with lsvtec - Vtec engages at startup
Different ecu, same problem. Led has worked numerous times before. I'm leaning towards the Neptune. I'm going to use my buddies ecu today to see the values of the sensors while car is running. See what's going on. But right now seeing if anyone else has any other ideas. I'll try an remove the led for the sake of diagnosis
True, I just know prior to using Neptune it worked flawlessly, led would come on, car would pull awesome. You could hear/feel crossover when the led would illuminate. It Illuminates at random upon startup and bogs. Then the led goes off car runs fine. So from that, I can assume the solenoid is receiving signal from the ecu. It's also inline with the vtec solenoid and the pressure sensor is disabled through the ecu.
Not swearing it's the tune, but that's all I can think of that would be different from when it worked everyday to hardly at all. Car ran a year and a half on crome perfect and with the Neptune it's where I noticing the issue. Not saying neptune is the problem at all. Just the only different variable between working and not. Prior the Lsvtec was on its last legs so I just let it go and assumed it was a mechanical problem. Now with the gsr I'm still experiencing the same issue. I don't necessarily care if vtec works or not it's the ocd in me that wants to figure out what's going on.
The Grumpiest
Is it a GSR or an LS/VTEC? I'm confused.
Originally Lsvtec now gsr. I just didn't update first post so I didn't confuse anyone. I see that was a bad move. I'm gonna try my original crome ecu today if we can't figure anything out with the live readings
For anyone concerned or for any potential future searches that lead to this thread, the problem was found.
For some reason, the Ecu would engage vtec at startup randomly. New ecu no problems. Ecu was put into another car and that car had no vtec. Not sure why it happened as the Ecu looks fine, will dive down deeper and see what happened. I want to thank everyone who had any input on what to do. In my research came across a lot of things I would have never looked for otherwise.
