94 Civic EX not cranking
Old Jun 30, 2014 | 09:45 AM
backwoods tuner's Avatar
Icon6 94 Civic EX not cranking
we have a 94 civic with a 1.5L, 5 speed tranny, wont start. getting power to the starter. Wont crank. checked the fuses and replaced the starter already. engine will roll over manualy. wondering if anyone has had this problem before. Any sugestions?
Old Jun 30, 2014 | 11:09 AM
Former User's Avatar
Default Re: 94 Civic EX not starting
Rubber stopper at top of clutch pedal - did it fall out?
Old Jun 30, 2014 | 12:21 PM
Default Re: 94 Civic EX not cranking
nope, its still there. but thanks for that! didnt think to look there.
Old Jun 30, 2014 | 12:37 PM
Did you check the right stopper? The pedal has two.
Old Jun 30, 2014 | 12:46 PM
visiblystealthy's Avatar
Bypass said switch behind clutch pedal(not permanently) see if it starts. Free to do, and will help narrow down your problem.
Old Jun 30, 2014 | 01:02 PM
shotoutacc0rd's Avatar
Bypassing that switch and putting in a new switch somewhere else isn't a bad idea at all.
Old Jun 30, 2014 | 02:06 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Actually it is not a good idea. The Neutral Safety Switch is there to prevent you from trying to start the car with it in gear. Really hard on the starter.
Bypassing it will let you rule it out as your no crank condition, but to leave it bypassed or some manual switch elsewhere is asking for mishap somewhere down the road being you won't have to disengage the clutch to crank the car. Eventually yer gonna make the car hop forward or reverse depending on what gear you like to leave it in and it may not be a good spot to jump forward or backward in. Or at the very least you will stress the crap out of the starter from time to time as it tries to move an immovable object.
Old Jul 7, 2014 | 07:25 AM
Thanks for all the suggestions guys! We bypassed the neutral safety switch and it cranked, so we are ordering a new switch.
Nikki Aulicino
Jan 26, 2017 10:25 PM
J3450
Mar 18, 2012 09:43 PM
91EF_Si
Aug 25, 2010 12:35 PM
omgwtfbbq
Oct 20, 2009 06:48 PM
DrewQ1
May 4, 2004 09:14 PM
