d15b2 to d16z6 swap
First I would like to know how to identify what car this d16z6 motor was out of.. Was told 07 civic 26k miles was rolled and motor been sitting g for 4 years... I have pic In my album. Second this is VTEC and mine is not, so wondering what parts am going to need for this swap??? This is a multi injection(4injectors) motor going into a dual point I ejection system..
1st am I going to need a ecm out of car from Motor or can I use any vtech ecm or just chip ecm I got..
2nd if needed ecm will it plug into my harness...
3rd will my harness under hood plug into motor or do I need to do some splicing, is there conversion kits...
I'm poor so cheaper the better.
4th since I have whole motor which is better putting motor in or just doing mini me swap, which produces more hbp with better fuel economy...
If any one could answer any of the above queztions it would be great and if anyo e has any input or personal experience they would like to share is more than Welcome to pin it... thanx honda tech and have a great day.... you can email me directly @ kkaindabirdkilla@yahoo or just post here either way I will get it thank you again....
DIRTY BIRD.. AKA ech3
I can tell that you have done very little (or maybe none at all) searching on this site or on the internet for these answers.
This is a very common swap so you should have no problem finding anything you need to know.
Since you have under 10 posts, I'll give you the answers.
Next time, please check the top of the forum in the FAQ sticky and do your homework on Google.
D16Z6 was offered in the 92~95 Civic Si hatchback, Civic EX, and Del Sol Si. Somebody told you a fib when they told you it was from an '07.
There s some wiring you will need to deal with to get vtec to work. As the same with the vtec, you will also need to do some wiring to support the 2 additional injectors.
The DPFI to MPFI conversion is what you will need to look for regarding the 2 injector to 4 injector conversion.
1) You should use the ECU that the engine originally came with for it to run like it was originally intended to. There are other ECUs of the 92~95 years than can be modified to run your engine properly. Your current ECU can -NOT- be used.
2) The 92~95 ECU will not plug into your harness. You will need a 'jumper' harness to convert from your stock pre-OBD (commonly refered to as OBD0) wiring to the OBD1 layout (wiring supported in 92~95). This will also include a couple wires for updated engine electronics which are very easy to incorporate.
3) For easy and simplicity, you should use your stock engine harness and adapt it to your new motor. Swapping engine harnesses results in a wiring nightmare because the newer engine harness will not plug into the connectors to pass through the firewall.
4) If you have the entire engine to swap in, then that is the way to go.
The heck if I'm going to email you.
LOL. I totally agree with 4drEF, as usual. He was pretty blunt about it too.
Links to help this thread for anyone who finds it during a search.
D16Z6 EF SWAP:
http://www.geocities.com/bing_bong916/vtec.html
DPFI to MPFI SWAP:
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
OBD0 to OBD1 SWAP:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-obd0-obd1-3175858/
D16Z6 EF SWAP:
DPFI to MPFI SWAP:
OBD0 to OBD1 SWAP:
But I also understand that searching leads to many dead ends. Sometimes you get old information that is out of date too. And the worst thing, for me, is broken picture links. I'm a very visual learner and I feel much more confident when I can see things. But searching is usually much faster than relying on someone else to answer a question that has been answered before.
Also, OP, definitely swap the whole D16Z6 in there. Works way better than any mini-me. And next time search before you believe that your 20 year old motor came in a 7 year old car, sat for a couple years completely protected and only has 26k on the clock.
That's the motor from your album.
Here are the '07 motors. The R18 and K20.
Here is a D16Z6 VTEC motor.
Your Z6 is probably from a Del Sol. I believe it was the 1994 model or something that came without a stamped valve cover. But you still have the solenoid so it should be a VTEC head. Just confirm the stamp on the engine block, left of the exhaust manifold. Also, check the compression on it before you go too far. You can hook a started up to the motor and spin it off a battery before you put it in the car.
Thank you every body foryour replies.. Ihave done some research.. Not too much.. (i can take critisizim)don't mind my spelling... I've just recently in past few years been into hondas.. Was Chevy man for years before that.. Ihad read about the dizzy or jumper wire and the writingin of the extra injector wires.... And also found out that in07 was the year that the car was wrecked.. I too am a visual learner as well... People that know me know i always research things i don't know before anything... Hints me having motor for2 months in same spot.. (not in my car)lol i do thank you for your information and one day i shall pass it on..isn't that how is suppose to work? ;p lol.. Hopefully ican get the computer and jumper wire soon... I will update and send out even more thanks when it's done...
quotes of the day(DRIVE IT LIKE YOU STOLE IT)(can't find em grind em)
pli
13
Sep 2, 2007 05:54 PM
kevbo82
May 2, 2005 05:13 PM
Gee.Orgie
18
Oct 19, 2004 09:07 AM
