Switch on driver's door Can open but can't close the rear window at driver side
Hi, Everyone,
I have 2003 honda civic EX, using the switch on driver's door can open, but can't close the rear window at driver side. What is the problem ? How Can I fix it ?
Thanks,
Fujun
Thanks,
Fujun
Does the rear window switch work both ways? If so, then it's a bad connection or the master switch is bad. If the rear window switch does the same thing then it's a bad connection or that switch. You would actually have to pull the connector apart to see if the connections are good
That rules out that switch and a bad connection. Your master switch is bad. There's all sorts of places to get a new switch. You can take a chance on a used one (eBay, craigslist, nationwide salvage listings: http://www.car-part.com/) or get a new one from the dealer. FYI: Usually the online dealers are way cheaper.
einzelherz
Aug 26, 2013 06:41 AM
