Cruise Control problems
Old Jun 29, 2014 | 12:26 PM
joeshag's Avatar
Default Cruise Control problems
Hello I have a 1998 Honda Civic Lx. I have recently been experiencing some cruise control problems. It will not engage. The button to the left of the dash is on, I press the bottom button on the steering wheel and the cruise control light comes on on the dash, however it will not maintain the set speed. Any help would be awesome! Thanks in advance!
Old Jun 29, 2014 | 12:35 PM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Cruise Control problems
You may have an erratic signal coming from the VSS sensor. Sometimes this shows up on the speedo acting funny or twitchy for a moment.
You may have a vacuum issue with the actuator where the signal is weak or a stuck open check valve. If it isn't reacting quickly as before, there could be a binding cable too from the actuator to the throtle body.
good luck
Old Jun 29, 2014 | 04:35 PM
joeshag's Avatar
I haven't noticed anything twitchy or funny with the speedometer. Kinda weird.
Old Jun 29, 2014 | 05:49 PM
Former User's Avatar
Check whether the vacuum hose is disconnected at the IM, vacuum tank, or actuator.
Also inspect the cable.
Old Jun 29, 2014 | 06:30 PM
joeshag's Avatar
Okay, is there a diagram of where I can find the vacuum hose?
Old Jun 29, 2014 | 07:01 PM
Post pictures of the actuator and the cable and vacuum hoses that route from the actuator to the vacuum tank and then to the IM.
Old Jun 30, 2014 | 02:51 PM
joeshag's Avatar
http://imgur.com/MQcbRgd
http://imgur.com/uHleTwJ
http://imgur.com/TO8ALvE
Everything seems to look fine. Bad actuator?
Old Jun 30, 2014 | 03:06 PM
joeshag's Avatar
Found problem, hose near the power steering reservoir was completely off. Thanks guys.
Old Jun 30, 2014 | 03:13 PM
joeshag
Jul 28, 2014 08:45 AM
Mr. H_Twizzle
Aug 26, 2013 05:12 AM
obuhmyuh
Jun 7, 2008 06:43 PM
flood
Jan 14, 2005 10:08 AM
Greyout
Apr 16, 2002 10:02 PM
