Coolant temp sending unit connector broke
Old Jun 28, 2014 | 04:15 PM
austinramsay's Avatar
Default Coolant temp sending unit connector broke
The 1 wire coolant temp sending unit connector under the dizzy on my crx was hanging on by 1 wire and came off. Where can I get another connector? Can I find a new one somewhere or do I just have to get a used one? Can I use one of those bullet connectors on it?
Old Jun 28, 2014 | 05:25 PM
Freemananana's Avatar
Default Re: Coolant temp sending unit connector broke
You can use any connector you want. OEM ones are cheap though. Junkyards have plenty of them for free most of the time.
Old Jun 29, 2014 | 05:24 PM
racin_jayson's Avatar
You can use a regular bullet connector on the one wire sending unit connector, it works fine.
If you're ever looking for new oem style connectors for other sensors, and you don't want used ones that you have to solder, Chasebays sells individual connectors with new pins and weather seals.
popppinvtec
10
Jul 8, 2011 09:25 AM
ekhatchey
Jan 7, 2010 10:04 AM
crxkid24
Sep 21, 2007 07:39 PM
zccr-xsi
11
Feb 20, 2006 04:11 PM
VTECR021
Apr 22, 2004 08:04 PM
