Si cams just as good as Gsr for turbo???
Old Oct 30, 2002 | 08:34 PM
its WANG yoO's Avatar
Default Si cams just as good as Gsr for turbo???
i have a set of Si cams from a 99' i was wondering in my Itr head with Ferrea springs/retainers..would they be just as good as gsr cams???
plan on running about 20-25lbs...
Old Oct 30, 2002 | 08:37 PM
texan's Avatar
Default Re: Si cams just as good as Gsr for turbo??? (hybridRhatch)
At that level of boost you'd be better off with a set of cams designed for high boost turbocharged appllications. NA cams are NOT the ideal way to go.
Old Oct 30, 2002 | 08:51 PM
Default Re: Si cams just as good as Gsr for turbo??? (texan)
that dude with the 88 crx runnin 9's is using gsr cams..stock...and he's runnin a t4/60-1 turbo..with i'm guessing tons of boost...everyone says to run gsr cams...i was just wondering it Si cams are the same???
Old Oct 30, 2002 | 09:09 PM
skilzz's Avatar
No the Gs-r cams in leyman's terms are "lazier" than the Si's (which is ok for turbo)... Si's are a bit more aggressive but not by much. (not ideal for turbo but won't kill you)
Old Oct 30, 2002 | 09:11 PM
Civic Power's Avatar
New User
GSR Cams Better Than Si Cams
attack666
Apr 30, 2010 04:46 PM
hoskos
Aug 16, 2006 06:16 PM
crexer
Feb 20, 2003 06:43 PM
