1996 honda accord..damn brakes wont bleed properly
Ok i had to swap master cylinder and the brake boost(replaced with new ones)
I bench bled the master as well as i could.. stupid supplied plastic nipple things are not worth a damn.. so when installing on car i bench bled it again to make sure there was as little air in there as possible..
Now tried bleeding tried bleeding the system and nothing.. cant seem to build pressure but im not leaking any pressure no fluid ether..
tried bleeding all the brakes.. tried bleeding the dam abs..
frustrated beyond all known possibilities now lol/..
Did you buy a new or used MC? Used MCs can be bad right out of the box, not worth the savings.
How did you bleed the system? Driver rear/Pass front + Pass Rear/Driver front? Bleed the ABS last.
