H22A Vtec doesn't work after swapping to manual gearbox (but there is a pressure on t
Old Jun 25, 2014 | 02:56 AM
maloy's Avatar
Default H22A Vtec doesn't work after swapping to manual gearbox (but there is a pressure on t
I swapped to manual gearbox and Vtec stopped working. Control module was soldered for manual gearbox. Valve works and gives pressure of 5 atm. But nothing changes, not even the sound. Before swapping Vtec was working properly.
Old Jun 25, 2014 | 07:56 AM
snobordboy's Avatar
Moderator
Default Re: H22A Vtec doesn't work after swapping to manual gearbox (but there is a pressure
Double check all of your wiring. Is the VSS working, or are there any cel codes?
nelsond
Dec 4, 2006 12:22 PM
EsQueue
Sep 14, 2003 06:10 PM
