D16y7 iacv problems
Old Jun 24, 2014 | 04:28 PM
Cpt.trips's Avatar
Default D16y7 iacv problems
Hey all.
i took off and cleaned entire intake manifold and fuel rail on my96. I cleaned the iacv and reassembled everything.the car now has the infamous erratic-idol.i have taken it off and recleaned. I also replaced with another used and cleaned one with no help.
i ended up deleting it with a piece of aluminum can as I saw in a previous post.it is much beter but this is obviously temporary.
Any ideas? Thanks
Old Jun 24, 2014 | 04:49 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: D16y7 iacv problems
Why did you remove it and clean it in the first place? Did you replace all of the gaskets?
Old Jun 24, 2014 | 05:15 PM
Cpt.trips's Avatar
Basically just to overhaul.has never ben cleaned in 270kmiles. I replaced all gaskets.no vacuum or fuel leaks.the idol before was a little high but steady. without the can blocking it now it idols out of control.
Old Jun 24, 2014 | 05:21 PM
HondaPartsHero's Avatar
Technical Hero
Bleed the coolant? Check for vacuum leaks?
Old Jun 24, 2014 | 05:27 PM
NotARaCist's Avatar
So you ignored the basic concept of "if it ain't broke, don't fix it", and you broke it.
Bleed your coolant, check for vacuum leaks. Did you fully disassemble the IACV to clean it, or did you just spray it out and reinstall?
Old Jun 24, 2014 | 05:30 PM
Cpt.trips's Avatar
Drained system Replaced all hoses with silicon hoses ,aluminum radiator,thermostat. Everything is full and running. I've actually ben driving it for few months like this.All the vacuumed lines are secure and there is no leaks. I'm trying to avoid buying new iacv since I have 2 and I know there fine. What's the proper way to bleed without using the funnel.i know y7 has no bleeder screw.
Old Jun 24, 2014 | 05:32 PM
NotARaCist's Avatar
Put the front end of the car on jack stands, or park it up a hill. Remove the radiator cap. start the car, and let it run. When it reaches operating temperature, the fan should turn on. Let the fan cycle on and off three times, while keeping the radiator and reservoir full.
Old Jun 24, 2014 | 05:42 PM
Cpt.trips's Avatar
Dude.thats exactly it.it was trying to improve mpg by cleaning out mani and injectors.and now it idols shittyer
Old Jun 24, 2014 | 05:45 PM
Cpt.trips's Avatar
I did that except I wasn't on a hill.i just kept adding to the radiator while the fan cycled.should I do it again while the front is up?
Old Jun 24, 2014 | 05:53 PM
NotARaCist's Avatar
Yes. Air will go to the highest point in the system. If the car is sitting level, the radiator cap will not be the highest point, and air will bubble up in the cooling system. Jack up the front end, repeat process.
You don't need to disassemble the entire intake assembly to clean it. There are chemicals that'll do that for you.
Old Jun 24, 2014 | 06:07 PM
Cpt.trips's Avatar
.in the manifold i swear the air was restricted by like 30% so much **** caked in there.all around the injectors too.it was too much to just burn through.i wanted to clean the outside too.make it shine.you know.
Ill try to bleed out any air tomorrow.thanks buddy
90CB7EX
Nov 10, 2016 04:13 PM
krysted9354
11
Mar 4, 2009 04:27 PM
1kleenef
Sep 30, 2007 10:09 AM
mattL
Mar 21, 2004 03:06 PM
sleepyhamsterlx
Jan 5, 2004 07:10 PM
