crank but not starting
Old Jun 24, 2014 | 08:59 AM
arcticbluealex's Avatar
Default crank but not starting
Ok so here's what happened, turned off car went to eat came back out, not starting. I got a check engine light for misfire in cylinder 3. Cranks but wont start and I have no idea what to do.
Here's what I replaced trying to get it to work:
Cap n rotor
Ignition control module
Ignition coil
Main relay
Spark plugs
Im running out of things to replace, its like its not getting gas but I smell gas in the throttle body and hear the fuel pump prime? Any help would be nice
Old Jul 8, 2014 | 12:17 PM
widewhite's Avatar
Default Re: crank but not starting
did u check to see if you were getting spark thru the wires and to the plugs, you could have a faulty dizzy.
Old Jul 8, 2014 | 01:03 PM
holmesnmanny's Avatar
Check for spark and fuel.
Old Jul 8, 2014 | 08:06 PM
civic-steve-94's Avatar
Back to the basics check of spark. Crank engine then pull plugs and check if they are wet with fuel. If you have those check for compression.
tyler100
Aug 24, 2008 06:28 AM
masterp
Dec 5, 2006 02:26 PM
geezer06
Oct 26, 2003 09:14 PM
g2turbo
Sep 17, 2003 08:31 PM
paulzy
Dec 26, 2002 03:46 PM
