Parking brake light won't go off after changing drums.
Old Jun 22, 2014 | 04:17 PM
woodenchef's Avatar
Default Parking brake light won't go off after changing drums.
Today I changed my drum brakes. After adjusting the drums breaks so there was a slight drag. I put everything back together and went to adjust my parking brake. I noticed the parking brake light was on while the handle was (fully down). When I raised in the parking brake light brightens a tad bit, but when I put it back down it dims a bit, but still does not shut off. What could of caused this was working fine before?
Old Jun 23, 2014 | 11:38 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Parking brake light won't go off after changing drums.
Check the brake fluid level. Sometimes the float on GM trucks gets stuck at the bottom......
Old Jun 23, 2014 | 11:59 AM
woodenchef's Avatar
Yeah, today I looked, and my fluid level was low. I forgot to top it up the last when I bleed the last cylinder. Then when I got in my car put the e-brake down the light went off. So the float in the master, will send a signal to your car when the fluid level is low? I did not know that. At least on a older car this age.
FK00GSR
Nov 7, 2003 12:32 PM
94BlackRS
Nov 28, 2002 02:43 PM
Slow
Oct 29, 2002 03:38 PM
SlowazzGSR
Jun 7, 2002 10:30 PM
hybridbmw
Feb 19, 2002 10:38 AM
