Need info
Old Jun 21, 2014 | 06:00 PM
Shanasman12's Avatar
Default Need info
Can anyone help me find info on what would be involved in using a d16y7 head on a d16z6? Also need info on converting my car to a manual 5-speed from an auto if anyone can help. Doing a full rebuild and want to take care of everything at one time so any help or info helps. Thanks.
Old Jun 22, 2014 | 01:41 AM
Okay so I've done some googling and would like to rephrase my question a bit. First off, I'm not looking for a race ready engine. This is going to be a daily driver. I'm looking at maybe using some aftermarket internals. I know I'm looking for a higher compression rate which is why i asked about the y7 head at first. Now however I'm seeing that the y8 head with 5000 ths milled off would work better so I need some thoughts on that. I'm also looking at aftermarket pistons as well and rods to if compression gets to be to high for stock rods. Thinking of getting a stage 1 or 2 cam and an adjustable cam gear and aftermarket valve springs and such depending on what cam I end up going with. Might even be looking at chipping the ecu. The stock z6 comes with the p28 ecu from the factory correct? All I'm really looking for is a little help deciding what would be best for me. Any input is appreciated. Thanks y'all.
Old Jun 22, 2014 | 04:15 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Need info
And never says what he's trying to do with all these cockamamie mods
Old Jun 22, 2014 | 05:10 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
He is trying to make a daily driver with race parts y0!
OP - Even though you should be focusing on getting a better job and taking care of your child first, you need to understand the basics. Every single piece of information you ask about has literally been done 100's of times with dozens of write-ups available on the internet. If you have extra money to blow you should just purchase a different car all together to get what you want and call it a day.
You may only pick two:
Cheap - Fast - Reliable
If you want it to be fast and cheap, it won't be reliable.
If you want it to be fast and reliable, it won't be cheap.
If you want it to be reliable and cheap, it won't be fast.
Old Jun 22, 2014 | 08:01 AM
Yes I did, I'm making a daily driver.
[QUOTE"OneBadTurboCRV"]He is trying to make a daily driver with race parts y0!
If you want it to be reliable and cheap, it won't be fast.[/QUOTE]
I appreciate your concern for my family's welfare, however it just so happens that I DO have a better job. This is not going to be one big build. I'm spacing this out so I don't spend all of or money at one time. I'm trying to be smart about this since I'm having to rebuild anyway. The motor in its current state is missing in two cylinders. And I realize that there are hundreds of write ups on this but none of them are going to be specific to my need specifically. Thus why I asked "I need help deciding what's best for me". I'm not wanting "race part", only aftermarket parts with slightly better performance than OEM parts. Please believe me, I'm trying to be sensible about this. Again, thank you for your concern about our welfare.
Old Jun 22, 2014 | 08:05 AM
The Grumpiest
Daily driver doesn't tell anyone anything. If you want a daily then leave it stock. What are you hard goals? or do you not know?
Old Jun 22, 2014 | 08:59 AM
I know I'm replacing the cam and pistons, anything else is optional to me. My goal is to hit 150 whp or more without losing to much in reliability or gas mileage.
Old Jun 22, 2014 | 09:30 AM
The Grumpiest
All your questions have already been answered here.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/
Start reading.
Old Jun 22, 2014 | 09:36 AM
I'm not trying to bust anyone's ***** here but I only need my question answered. If not here then I'll get the info somewhere else. But regardless I'm going to set my car up how I want so please don't try to convince me otherwise. I asked because I'm looking for a set up that's right for me. If I had wanted a set up someone else has set up for their taste then it wouldn't be the same. To each their own right? All I'm looking for is opinion on how I should set my car up for daily driving and some fun on the weekends.
Old Jun 22, 2014 | 09:46 AM
The Grumpiest
The "somewhere else" would be at the link I gave you. All this has been done and answered before. If you want a step by step and parts list you'll find it there. Unfortunately no one is going to hold your hand and find it FOR you when it's right on front of your face. NOTHING you plan to do is new so you're not doing anything unique. You're not planting any flags. It's been done before so you have NO CHOICE but to do something that someone else has already done.
Old Jun 22, 2014 | 09:48 AM
The Grumpiest
I'm not the only one telling you.
Old Jun 23, 2014 | 07:15 PM
All you posted was a link to the all motor section of the forum. Don't you think I tried there. The reason I asked is cause I haven't had any luck looking for myself. I realize you think that I'm being lazy and asking for someone else to do it for me but you don't know my specific situation. All you need to know is that I have looked and haven't had luck and need help. If you aren't willing to help then go back to whatever it is you like to do in your free time, cause I'm not wasting mine on you.
Mods, if you want more members you need to rein in ******** like these.
Old Jun 24, 2014 | 03:35 AM
The Grumpiest
Do you actually think anyone is going to believe that you haven't had any luck finding any information on getting 150hp out of a D-series motor, or how to do a Mini-Me? Get up off of your *** and look! There are plenty of build threads with people doing similar builds. YOu aren't going to come up with a "different" combo or something no one else is running. Are you kidding me? You want hand holding! NO one is going to do that. The info is out there. You're just showing that you're too lazy/impatient to actually read and learn.
Stop throwing tantrums. You don't want to give up any information about your situation. It's like pulling teeth. You are being vague on purpose, giving up NO information YET you want members to give you EVERYTHING you want to know, because you say so? Bad attitude. Hence the reason no one is responding to this post.
Old Jun 24, 2014 | 08:54 AM
You don't have to believe me. You don't know how i spend my time every day. I never said I'm looking for a different combo. I know its been done before. But do you honestly believe that of the hundreds of threads out there I'm going to find one of the very few that are specific to my situation? I'm not throwing tantrums, I'm just sick of dealing with ******** like you. All I asked for was a little info and this is how you act? No offense but go step on a Lego and **** off. I'm done with this thread and this forum.
Old Jun 24, 2014 | 02:18 PM
toyomatt84's Avatar
Sanji
Realistically, you could have looked at the FAQ's thread in the link grumblemarc posted... and you would have found this thread: https://honda-tech.com/forums/all-motor-naturally-aspirated-44/all-motor-%2A-sohc-%2A-chime-1771904/
Old Jun 24, 2014 | 04:50 PM
The Grumpiest
And right to the end refuses to tell anyone what this special "situation" is that no existing information in all of the internet can help him with.
Old Jun 25, 2014 | 01:34 AM
m4xwellmurd3r's Avatar
You want to know the easiest way to get 150hp reliably out of a d series? Drop it out of a boat and swap in a b series vtec engine.
Old Jul 4, 2014 | 09:04 PM
Just to set the record straight, you're right. I apologize for the bad attitude, laziness, and vagueness. I have since answered my own questions and decided just to leave it stock besides the intake and exhaust (not that you likely care though after all this). Just mainly wanted to apologize though.
mtriples
25
Apr 17, 2010 08:39 AM
lsdb1
Aug 27, 2009 07:22 AM
Crazy4Honda
35
Dec 30, 2006 09:01 PM
chillax
Jun 5, 2003 07:09 AM
Red_Si
13
Oct 19, 2002 05:37 PM
