98 EX, JDM D15B, with stock harness and P2J-J11 ECU
Old Jun 19, 2014 | 05:51 PM
guapanese's Avatar
Default 98 EX, JDM D15B, with stock harness and P2J-J11 ECU
The D16Y8 blew in my 98 EX. I purchased a JDM D15B 3-stage VTEC engine with the stock (currently attached to engine) harness and P2J-J11 ECU. The engine also has the stock intake and exhaust manifolds, distributor, and every other stock accessory.
Anyone know any issues I'm going to have?
Old Jun 19, 2014 | 06:34 PM
shotoutacc0rd's Avatar
Default Re: 98 EX, JDM D15B, with stock harness and P2J-J11 ECU
You're gonna need to pass emissions, but that shouldn't be too complicated.
Old Jun 19, 2014 | 11:13 PM
guapanese's Avatar
I think I decided on doing the D16Y8 head with the D15B cam gear and VX timing belt.
I don't think I'd be able how to get the D15B to run with a P2P ECU and harness. I wouldn't be able to do the RPM switch thing.
Old Jun 20, 2014 | 12:58 AM
78F350's Avatar
I've been up all night doing further research and realized this. At the moment, I'm thinking of doing D16Y8 head with D15B block and D15 cam gear and VX timing belt. I'm not sure I'd be able to get it working correctly with the J11 or 003 ECU because I don't think I have the knowledge necessary.
Don't give up too fast. It may be hard to figure out, but it can be done. Can you figure out wiring diagrams and ECU pin-outs? If you have all the right pieces, you may have to fabricate some of the wire harness, but in the end its just a matter of getting the right wire to the right connector.
Old Jun 20, 2014 | 03:07 AM
grumblemarc's Avatar
The Grumpiest
What is so hard about running an OBD2a to OBD2b adapter as mentioned in the thread no one read?
Old Jun 20, 2014 | 04:01 AM
tony_2018's Avatar
Fish Twig
Do some research, a thread was created by djslim23 who had swapped one of these. I was a part of that thread.
Old Jun 20, 2014 | 05:43 AM
guapanese's Avatar
You guys act like everybody on this ******* website is an expert. Clearly I did enough research to decide to cancel the transaction of the D15B and do something more suitable to my non-expert self.
Not everyone can read diagrams and pinouts, and grumbleasscrack, it's not as simple as JUST using an adapter. You know how I know that? FROM ******* READING!
Have a good day.
Old Jun 20, 2014 | 05:52 AM
The Grumpiest
I think I'm about done with new users deciding to go juvenile and resort to name calling when it is not called and fueled by their own shortcomings. Too many times noobs claim to have read and get mad when they're shown that they haven't. Clearly this is the case here.
What are you having problems wrapping your head around? Get a harness adapter!!! How do you know it's not as simple as a harness adapter? But you're right. If you can't read a diagram then the swap was obviously beyond you. Good thinking to take an easier route and save yourself frustration and embarrassment. But when you get that JDM engine and have to do that CKF bypass trick you'll be back.
Old Jun 20, 2014 | 06:04 AM
The Grumpiest
Because if the following set of simple instructions if kicking your ***. You might want to rethink your plans to swap in anything.
Originally Posted by djslim23
I got my p2j ecu from Hmotors for those interested...so don't pm me lol
So, since there seems to be a relatively strong interest in this thread, I figured I'd start from square one..
A brief summary of what my setup includes:
1) *All in a '99 Civic LX Sedan*
2) 96-98 JDM D15B 3-stage vtec motor (99-00 are 3-stagers as well)
3) 96-00 D16Y5 m/t intake manifold, reusing all sensors from d15 (comes out of 96-00 civic HX m/t)
4) 99-00 D16Y7 engine harness (existing harness)
5) 96-98 JDM P2J-003 ECU (connected to 99-00 harness using cheap conversion harness)
6) My own wiring: EGR, knock sensor, IACV fix, vtec, and o2 sensor fix.
7) EGR solenoid for vacuum line leading to EGR (IN PROGRESS)
3/19/11 Update:
No CEL, only a slight bog when cold, but I attribute that to a slight vacuum leak that I have been putting off fixing (between intake mani and head).
Parts and Prices So Far...(in order (that I realized I needed it/them ))
Random things for swap - $50
Engine - $850
ECU - $200
Subharness (OBD2a to OBD2b) - $40
New soldering iron and wire and such stuff - $80
D16Y5 intake manifold and throttle body - $150 (hard to find in 5spd, out of Civic HX)
2-Wire IACV Plug - $10
Total so far: over $1300
Tech sheet: ---More to be added--- lazy right now
OBD2A IACV fix and Pinout
Everything that needs to be done:
1. Acquire a 96-00 d15b engine
2. Acquire a P2J-xxx ecu (P2J-003 for OBDIIa M/T, P2J-J11 for OBDIIb M/T, P2J-J61/J62 for ?)
3. See if your intake manifold has a 2 or 3 wire IACV (plastic doo-hicky on the back of the intake manifold)
------a. 3-wire IACV means you have an engine out of an automatic Civic Vti/Vi-RS and it will not work with manual ECU.
------b. 2-wire IACV means you have an engine out of a manual Civic Vti/Vi-RS (quite rare), and it will not work with automatic ECU.
*One way to solve this is to swap out the intake manifold completely, and since JDM d15b's aren't laying around in many junk yards, you'll probably need to go with a different one that fits. The d16y5 shares a similar if not the same intake manifold since it is a VTEC-E motor and has the EGR crap on it. You can find those in a 96-00 Civic HX (a little hard to find). Basically, you need to match manual IM to manual ECU and auto IM to auto ECU.* -I am still on this step and will need to update once I find more info..
4. Swap Motors and do regular swap related hooplah except for the wiring
5. Wiring
-----a. VTEC (2 solenoids)
++++++++2nd stage (16 Valve Mode) -- A21--red/green? test...
++++++++3rd stage (Vtec, same pin as USDM obd2a) -- A08--red/green? test...
b. EGR -- D9 (White/Black wire)
----- *Yellow/Blue wire taps into TPS sensor wire of same color
----- *Green/Black wire goes to junction connector in middle of engine bay
----- ***See update above regarding solenoid
c. O2 sensor (single wire) - depin your current O2 sensor plug on the plug side, then slide the pin in of the single wire sensor so that it lines up with the white wire on the engine side
d. Knock sensor
e. Lean Burn Mode (Econo Light in certain clusters) -- A30 (White/Red) to What pin location on the EK cluster???
When I get the correct info on this stuff, I'll edit it and leave it as a writeup since I've gone through hell and back finding out what I know so far.
Constantly Updated!
Old Jun 20, 2014 | 09:38 AM
tony_2018's Avatar
Fish Twig
That was the one. I didn't know anything about pinouts but I figured it out in timely fashion.
Old Jun 20, 2014 | 09:40 AM
tony_2018's Avatar
Fish Twig
Not to mention I figured out the pinouts for the obd2b ecu and confirmed the eco led pinouts as well.
Old Jun 20, 2014 | 09:53 AM
The Grumpiest
OP wants a plug and play install obviously; not being an expert nor being able to read diagrams and pinouts, not being able to do some sort of RPM switch thing I don't even see mentioned. But he's going to Frankenstein a motor?
Zulu451
Engine Management and Tuning
13
Feb 24, 2021 08:48 PM
Sfitz1018
Jun 22, 2017 09:39 AM
Wrench6
18
Jul 4, 2015 10:50 AM
GReddyTurboCoupe
Jun 12, 2005 07:05 PM
b1698civicex
Jan 26, 2004 02:33 PM
