My MoonRoof is leaking/ HELP!
Old Oct 30, 2002 | 07:06 PM
acuraLSSE95's Avatar
New User
Default My MoonRoof is leaking/ HELP!
I have a 95 SE with a factory moonroof. Recently I've noticed that the headliner/ceiling, above the sunvisors and to the rear of the moonroof, is a little wet/moist whenever it rains hard. How Do I fix this problem.
thanks
Old Oct 31, 2002 | 05:26 PM
New User
Default Re: My MoonRoof is leaking/ HELP! (acuraLSSE95)
anyone?
Old Oct 31, 2002 | 07:37 PM
SubieDude's Avatar
take it to the dealership...they'll know what to do....
Old Oct 31, 2002 | 07:46 PM
mr_mbuna's Avatar
Default Re: My MoonRoof is leaking/ HELP! (WhiteS2)
If there is water on mine, like the morning after it rains, and I open the 'roof while driving, it just pours into the cabin. Is it supposed to do this? Or do I have a bad/worn seal or something? Seems like they would've designed it with a high enough ridge on the front to prevent water from pouring onto people at the angle that the 'roof opens. I do have an OEM sunroof wind deflector, so maybe the water isn't getting blown away like it should.
Ben
Old Nov 1, 2002 | 03:23 AM
New User
it's a 95 so it's not under warranty, if i take it to the dealer, what will they do? and how much? Is there a way I could fix it myself by going to autostores and get something to seal it?
Old Nov 1, 2002 | 06:34 AM
b18bvtec4drteg's Avatar
Dude
All you have to do is pull your rear panels. Locate each tube 1 on the left rear and 1 on the right rear. There is bunch of debris clogging the tubes where the ends are at near the wheelwell. Take your fingers stick in the tube to clear the debris. You may also want to open the roof and look at the front 2 holes and see if they aren't plugged as well. I dont have the coupe but should be somewhat similar.
Old Nov 1, 2002 | 08:25 AM
New User
Default Re: My MoonRoof is leaking/ HELP! (b18bvtec4drteg)
I just slapped the rear panals back, you should have replied earlier...now I have to rip them apart again. . So exactly how's the tube located? I want to go right at it? how big is the tube?
Old Nov 1, 2002 | 10:21 AM
GSRaCeRbOI's Avatar
your drain tubes are probably clogged w/ dirt, leaves, etc... the tubes are probably 1/2" or maybe 3/8" just stick a pipe cleaner to clear the debris..
after it rains and if there is still water on the roof and moonroof glass.. if i tilt/open the moonroof water comes down.. or if i have it tilted/open and I brake water comes down into the cabin also...
Old Nov 1, 2002 | 10:38 AM
You can also look on the antenna (It also has a drain tube) and follow it to the main drain tube on the left side.
spoonhuntr
Sep 11, 2011 04:50 AM
dannyly17
Oct 27, 2009 05:00 PM
citrus3000psi
May 19, 2008 02:52 PM
wambus
11
Mar 24, 2003 07:52 AM
