92 honda civic grinding noise and won't start
Old Jun 18, 2014 | 03:48 PM
92HondaGirLL's Avatar
Default 92 honda civic grinding noise and won't start
Will make a grinding noise when trying to start and it won't ten if I give it a min and start it again it starts fine with no problem ! (( sorry if I posted this in the wrong place new to website ))
Old Jun 18, 2014 | 03:49 PM
Default Re: 92 honda civic grinding noise and won't start
Sorry 92 honda civic do with a d16 a motor in it and its manual transmission just for some back round info and we just swaped from a d15 to the d16 about 3 months ago
Old Jun 18, 2014 | 04:02 PM
1991_crxsi's Avatar
Starter teeth and/or flywheel teeth are damaged. Probably just the starter teeth though can't be sure without inspecting the car. Replacing the starter is fairly easy even for a novice while replacing the flywheel is quite a bit more involved. Fingers crossed that just needs the starter replaced. Good Luck.
Old Jun 18, 2014 | 04:12 PM
Well we just replaced the starter like 3 weeks ago .. The engine is a 96-2000 d16 an the starter is for a 92-95 d15 could that be a problem ? It matched up so we didn't think it was a big denal ... My husband and I do all the work on our cars but this one is stumping us
Old Jun 19, 2014 | 10:43 AM
Guess no one wants to help this week
Old Jun 19, 2014 | 12:39 PM
veks's Avatar
just by comparing part numbers those two starters are different. are you getting any cel codes? possibly a bad starter, weak battery, loose starter wire.
Old Jun 19, 2014 | 01:32 PM
1991_crxsi's Avatar
Don't be stumped. No one has responded because in all likelihood I already gave you the right answer. Your problem is almost certainly the starter teeth and/or flywheel teeth. Replace the stater and it will probably be fixed. The proper way would be to inspect the flywheel teeth as well to see if the flywheel needs to be replaced also.
Good Luck.
nopain20
Honda Civic (2006 - 2015)
Nov 7, 2014 09:32 PM
zeta
Oct 18, 2013 10:10 AM
EracerUgone
Nov 28, 2011 04:02 PM
RobertsCivic
Feb 27, 2010 10:59 AM
blakacintegra
Nov 7, 2007 01:16 PM
