Honda CR-V & Element 2WD & 4WD Element & CR-V
99/00 HR-V drinking problem
Old Jun 17, 2014 | 11:43 PM
OlafurArons's Avatar
Default 99/00 HR-V drinking problem
Hi friends.
I have a 1999/2000 Honda HR-V. It's done about 165.500km and since I bought it it's been drinking all oil I've put on it, at different speeds but emptied in under 1.000km (~500mi).
I went to the dealership in April and an old "expert" there told me the older Honda engines need thicker oil. So I went from 10-30 to 15-40 but with no difference what so ever. So what do i do? It's nit leaking anywhere.
Old Jun 18, 2014 | 06:02 AM
kiseliok's Avatar
Default Re: 99/00 HR-V drinking problem
Do you see the blue-ish smoke coming out of the the exhaust?
If you are not leaking oil then you are burning it it.
Either your head gasket is done for (more likely) or piston rings (less likely).
Also, I have no clue what hr-v is. This is a cr-v forum. Do you have pictures of your car?
Old Jun 18, 2014 | 11:15 AM
ARMED's Avatar
headgasket, piston rings, valve seals...
Old Jun 18, 2014 | 09:06 PM
There is no blue smoke.
There is no leaking oil from beneath the car.
I will check the headgasket as soon as i can afford to replace it, or do whatever needs to be done.
Wondering if i should bring it to the Honda dealership in Iceland since i get all the parts for free, only have to pay the labor, since my dad is good friends with one of the ceo's.
This is a 99/00 Honda HR-V Sport. 3 door. It's mine.
It's got the same poopy 4wd as the cr-v.
Old Jun 19, 2014 | 05:25 AM
kiseliok's Avatar
Now THAT is a rare car. Holy crap!
Old Jun 25, 2014 | 03:04 PM
maco35's Avatar
We need more pics. please, i've never seen one B4.
Old Jun 27, 2014 | 07:20 AM
red.da's Avatar
google it, there is a million pics on the internet.
As far as the oil consumption goes, have you done a compression test?
Old Jun 27, 2014 | 10:24 AM
Skillachie's Avatar
Not a rare car at all, just wasn't introduced to america
Old Jun 30, 2014 | 07:00 PM
I have not.
I highly doubt i have the tools required.
I'm taking it to a local repair shop soon, as i'm quite fed up with having to feed the engine something like 8 liters of oil for about 1800km.
If it can't be fixed cheap (for less than $800) then i'm getting rid of it and getting something else for my ground zero subwoofers.
Old Jul 3, 2014 | 05:25 AM
red.da's Avatar
Originally Posted by OlafurArons
I have not.
If you lived near me, i would buy that thing from you in a second! good luck with the fix and keep us posted.
Old Jul 3, 2014 | 05:30 AM
red.da's Avatar
I have not.
Old Jul 3, 2014 | 05:38 AM
red.da's Avatar
I have not.
Old Jul 3, 2014 | 07:40 AM
HiProfile's Avatar
The oil rings could be slugged up, letting lots of oil get into the cylinder. How do the spark plugs look? Google "reading spark plugs" and compare them to pictures. A while ago a relative let me work on her Toyota. It was burning lots of oil and the spark plugs had what looked like a greenish mold/lichen growing on them from the oil deposits.
Old Jul 12, 2014 | 03:28 PM
phideauxiii's Avatar
inDEED!! i'd say she's a keeper...
quick question, what altitude are you typically operating the vehicle at? (just curious)
I like the ride, i've never seen one in the states, although that's not so surprising. i've never even seen a Ford Ka over here, either, and they suffer a nearly universal ubiquity in parts of the EU/UK lol
drinking problem with no smoke. that oil is going somewhere, and "needing thicker oil" in an engine with as tight tolerances as Honda builds their motors to... may be doing yourself a disservice. I try to keep in mind that *rarely* if EVER is there anything that you can pour into yr car to "fix" such a grievous problem as monstrous oil consumption... it's always better to isolate the issue...
Which engine does that one have?
Old Jul 12, 2014 | 03:29 PM
if the rings were bad, oil would slip past into the combustion chamber and be... combusted. He'd see the Blue Smoke of Death at the tailpipe, no?
j2lowe
Oct 6, 2018 11:11 PM
gabriel0830
Nov 19, 2012 08:18 AM
king_jdm_si
Dec 16, 2010 07:13 AM
BigC-ivic
Aug 27, 2005 07:53 AM
1991HondaAccord
Dec 3, 2004 06:39 AM
