electeical issue lexus gs
Old Jun 17, 2014 | 07:25 PM
Spoolinls's Avatar
Default electeical issue lexus gs
So we picked up a 2002 Lexus gs300 for my wife and after we got it and it sat over night we found it had a bad battery. I replaced the battery around 9:30 am we went to take it to the store around 12 battery was stone dead. It will drain a brand new battery in about 2hrs. I put my multimeter on it was reading 12.40 with in 15 min it dropped to 9.80. Has a new alternator new starter new ecu new battery. I have pulled any fuse or relay I could find unplugged the ignition switch. Still can't find this voltage drain I know these cars tend to have a bunch of diodes and have only found 2. Any help would be great
Old Jun 18, 2014 | 04:52 AM
grumblemarc's Avatar
The Grumpiest
Default Re: electeical issue lexus gs
Have you actually tested for parasitic drain?
Old Jun 22, 2014 | 03:27 PM
Spoolinls's Avatar
You mean by hooking the meter in series with the battery? If so yes and it says it's drawing 8.34 amps
Old Jun 22, 2014 | 03:28 PM
Spoolinls's Avatar
Old Jun 22, 2014 | 04:04 PM
The Grumpiest
https://www.google.com/webhp?sourcei...rasitic%20draw
Old Jun 22, 2014 | 04:33 PM
Spoolinls's Avatar
That's same vidwobi watched and yes that what I am doing
Old Jun 22, 2014 | 07:16 PM
bambam's Avatar
I know on mid 2000's to about 2010/11 the HFL (hands free link) units i.e. bluetooth units caused a parasitic draw if they failed in hondas/acuras. Worth a shot since a third party designed the HFL units, and it may be the same manufacturer for Lexus.
Old Jun 22, 2014 | 07:54 PM
Spoolinls's Avatar
I was able to find it it was a 15amp fuse on the passenger side fuse box but there is no lid on it to tell which fuse it which. Anyone have a diagram for passenger pose box
Old Jun 22, 2014 | 08:06 PM
Spoolinls's Avatar
Need to know what this fuse in red is for
Old Jun 23, 2014 | 11:14 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Originally Posted by Spoolinls
You set it up right. But did you wait for at least 30 mins before testing? The modules need time to power down on their own. It is not unusual for modules to remain awake for almost an hour on some makes.
Accordign to my diagram,there is no fuse in that slot. There is a 15a fuse above it ,though,with the letters "TV" as its designation.
Dont know if those letters imply the obvious,or if it means something else in Toyota lingo,but youre likley gonna need a wiring diagram.
Old Jun 23, 2014 | 11:30 AM
Spoolinls's Avatar
I didn't have 30min by then the battery would be dead . Whatever the fuse it it doesn't affect anythin as far as I can tell lights horn Windows ect all still work
Old Jun 23, 2014 | 11:37 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
I didn't have 30min by then the battery would be dead....
Then the battery is bad as well. An 8a draw should not kill a battery in 30mins,if it does the RC of the battery is very low.
Old Jun 23, 2014 | 01:11 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
they may remain awake, but they shouldn't be pulling 8 amps, sounds almost like a transmission solonoid is stuck on or something
Old Jun 23, 2014 | 01:17 PM
the one marked TV actually means television, weird, but it's for the navigation screen, if there is a fuse in the empty slot below it, I would almost bet it's for the factory amplifier for the stereo, if it's not shutting off, it can pull quite a bit of current. Depends on if this car has the high end audio system, it's just like an aftermarket stereo that has a remote wire that malfunctions, if this happens the amp stays powered up and kills your battery
Old Jun 23, 2014 | 01:19 PM
Spoolinls's Avatar
No has a brand new battery 3 days old and already had it checked it was actually pulling 13.2amps that was showing 8 since it was draining the battery
Old Jun 23, 2014 | 04:53 PM
Spoolinls's Avatar
Ya it ended up being for the factory amp. Now the other issue ibhave it when the car is on the acc position the blower motor works and blows out of the vents but when the car is on the ON position to start it the blower shuts off and nothing comes out of the vents. Maybe a ignition switch or blower motor resistor?
TomSwift
Oct 16, 2006 02:07 PM
uNF$@#!
Jun 17, 2006 06:42 AM
Jonathan_ED3
May 20, 2004 01:44 PM
GroundZer0 336
Mar 6, 2004 05:55 PM
