s300 issues possibly. h22 turbo swap
Old Jun 16, 2014 | 10:21 PM
Manifest113's Avatar
Default s300 issues possibly. h22 turbo swap
Hey everyone im am having a issue with my car starting after my build.
I have a h22a1 swapped 94 cx hatch. Hondata s300 ecu. car ran and drove fine for over a year with this setup and no issues. I pulled the motor and put a h22a block in with a pnp h22a1 head and turboed the car. same wiring harness and everything that was used before no wiring was changed minus the injectors clips. i went from using stock injectors to using precsion 880cc injectors, larger rail etc. i know timing is correct and the dizzy is new so are the plugs and wires.
The issue is the motor will turn and turn but not start. i have tried everything i can think of and double checked everything but nothing. and i noticed the ecu/hondata light will be green but when i turn the key it turns red till i stop trying to crank the motor. i swapped ecu out to see if anything would change and same result. i had the ecu uploaded with a basemap from a shop that will be doing the tuning but the second ecu i have was used for a h22 and has a map and it wont start either. please and help would be awesome bc im at a loss. also do i need to be using a resistor for the injectors? i have a p06 and a p30 ecus. both have been used for this motor and chassis. thanks
Old Jun 17, 2014 | 05:11 AM
Muckman's Avatar
Moderator in Chief
Default Re: s300 issues possibly. h22 turbo swap
So you went from stock injectors to 880cc. Did you rescale the fuel tables?
There have been a lot of changes since the last setup. Whenever in doubt just it back to the way it worked before and change one thing at a time.
Old Jun 17, 2014 | 09:21 AM
yea the fuel map was rescaled. like i said i have a base map put on by the tuner whos gona do the dyno tuning. its made so i can drive it to the shop.
Old Jun 29, 2014 | 04:45 PM
VegasInvasion's Avatar
I'm Huge In Japan
either your calibration is inaccurate, you have some plugs backwards on the harness, you broke a sensor during the swap, or there's a wiring issue with your injector clips.
and/ or you're not using a resistor box. try posting a datalog file.
Manifest113
Jun 17, 2014 07:17 PM
PremiumPrelude
Mar 12, 2008 01:25 PM
Lan
Apr 3, 2006 03:17 PM
IN10SITY
May 24, 2004 02:06 PM
