94 ej1 - need help with OBD0 b16a swap
I'm wanting to throw a B16a in my 94 civic ex coupe. The b16a I have is an obd0. Is it possible to use the same obd1 harness instead of converting to an obd0 harness? Any suggestions?
-reuse your injectors
-92-93 GSR distributor or 94-95 Del Sol VTEC distributor
-94-01 Integra shift linkage or 99-00 shift linkage
-wire up knock sensor
-use OBD1 P30 or chipped P28 with P30 maps
-use header that has an 02 bung at the collector
-swap over VTEC connector off your old engine to the OBD0 engine as they are different styles
-you'll need to either reuse your throttle body or use one with the MAP sensor on top of it
-the rest should plug and play
-you can't use the transmission from it without a conversion kit
-94-01 integra axles or 99-00 axles
You'll also need to wire the fan switch from your thermostat housing area of your old engine to the back of the block of your new engine
HondaPartsHero
10
May 3, 2023 05:32 PM
jtaylor16
Aug 19, 2012 01:02 PM
v8 integra
14
Apr 17, 2006 05:49 PM
