Wideband
Old Jun 16, 2014 | 07:29 AM
Egalltheway's Avatar
Default Wideband
I have a turbo 89 crx. Has anybody ever wires up the plx wideband. Need help thanks
Old Jun 16, 2014 | 08:27 AM
Freemananana's Avatar
Default Re: Wideband
Oh dear god.
How did you get a turbo CRX?
It's very easy to wire. I'm nearly positive all you need is a ground, switched power, and a place to put it. You can wire it to the ECU, but if the car is already tuned there really is no need. You'll need an O2 bung on your downpipe, 36" after the turbo I think. That's what my AEM suggested (iirc). Maybe it was 18", read the install instructions.
Widebands are super easy. You do need a special drill bit to drill into pipe though. Keep that in mind.
Old Jun 16, 2014 | 09:11 AM
BLU CIVIC's Avatar
Track Advocate
http://www.plxdevices.com/support/ma...UsersGuide.pdf
Old Jun 16, 2014 | 11:13 AM
How can I wire it to the ecu
Old Jun 16, 2014 | 11:18 AM
BLU CIVIC's Avatar
Track Advocate
wire it to the ecu for what reason? what display are you using? i had the PLX SM-AFR wired to my tunerview
Old Jun 17, 2014 | 05:06 AM
Yes it is the plx sm-AFR want to wire it to the ecu to have a better tune. I'm running hondata s300 on it also
Old Jun 17, 2014 | 06:40 AM
Wiring a wideband will not enable a better tune.
Old Jun 17, 2014 | 06:43 AM
BLU CIVIC's Avatar
Track Advocate
http://www.xenocron.com/install/Xeno...etup-Guide.htm
Old Jun 18, 2014 | 06:21 AM
xenocron's Avatar
Certainly it will allow the tuner an easier way to accurately determine what fuel changes need to be made during the tune allowing a more efficient tuning process and more accurate IMHO.
I always recommend and ask customers to install a wideband and wire the voltage output to the ECU for LOGGING and tuning purposes.
Old Jun 18, 2014 | 08:11 AM
I agree. My point was more along the lines that the wideband O2 sensor itself will not change the current tune.
bcumbie
Engine Management and Tuning
Mar 16, 2012 08:49 PM
Alpinestar03
Jan 1, 2009 08:54 AM
Shakes
May 20, 2008 01:02 PM
R6E6I6D
Nov 16, 2005 09:35 PM
