Drive shaft suggestions ?
Hey guy's, Its time to replace the drive shafts on my dc2 and was wondering if anyone here could recommend some good reliable ones with 350hp rating?
http://www.driveshaftshop.com/import...75hp-level-2-9
I have looked at these ones, they look good but are a bit pricey ($1,300) shipped to Aus. also after reading through their warranty statement i'm a bit put off as one of the conditions of a 1yr warranty is that "It is at The Drive Shaft Shop's sole discretion to decide what is covered under warranty and what is not."
any help will be greatly appreciated
unless u doin some serious track/racing ill stick to raxles. fair price and life time warranty
http://www.raxles.com/
We have had good luck with stock replacement axles at the drag strip. They have held up on 22-24.5 inch slicks as well as both turbo and NA cars. We have had cars run well into the 11's on stock axles for multiple seasons now.
The car will eventually be a sole track car, by time it's fully built. I generally start with drive-train & suspension when planning. The parts last longer and less work required in fitting them. It's being used as a daily for now got a 2nd engine on a stand i'm working on slowly.
I forgot about them, heard they're pretty decent. will look into them again thanks
