Need diagram of ac belt layout
Old Jun 12, 2014 | 03:26 PM
Ef4doorwagon's Avatar
Default Need diagram of ac belt layout
My haynes has nothing specific on the ac belt layout, like how the idler pulley is suppose to be positioned. I got an ac belt frim autozone buti think it may be to small.
Old Jun 12, 2014 | 04:14 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Need diagram of ac belt layout
The idler pushes up on the belt.
BTW I found that picture by doing this http://lmgtfy.com/?q=91+civic+ac+belt and then going to images.
Old Jun 12, 2014 | 05:04 PM
Thanks. So the pulley pushes down on the belt to tension?
Old Jun 12, 2014 | 05:08 PM
24TEN's Avatar
PHANTOM MENACE
Old Jun 12, 2014 | 05:38 PM
Oh, sorry for posting dumb questions, but since it pushes up, that implies that the belt must be big enough to go over the compressor, the pulley and the crank?
Old Jun 12, 2014 | 10:29 PM
24TEN's Avatar
PHANTOM MENACE
The "adjusting bolt" is there to manipulate the position of the idler pulley. I believe you must loosen the "idler pulley center nut" before you make any adjustments.
Old Jun 14, 2014 | 12:01 PM
Tyson's Avatar
Makes sure theres a special washer between the pully and the thin metal seal.
Easily forgotten and misplaced and installed incorrectly. Your pulley will not work properly if it's missing or installed incorrectly. If you don't know what washer I'm talking about or don't have it, stop and look at the helms manual.
Old Jun 14, 2014 | 12:05 PM
F22Master's Avatar
Ef4doorwagon, download the 88-90 civic manual from here: http://hondatech.info/downloads/Auto/Manuals/Civic/
Then, you can reference the factory service manual for all of these little questions you have, instead of posting a new thread...
Old Jun 15, 2014 | 06:15 PM
d4g4m's Avatar
Loosen the tension nut and the center nut on the wheel.
The belt you need is 4PK870 with small numbers 2826
zcmotor
Oct 1, 2013 08:15 PM
adamsteve56
Jun 28, 2010 06:59 AM
V8wannabe
May 6, 2010 12:56 PM
AssPenny
Jul 14, 2002 07:14 AM
