civic 97 ex/LS VTEC Turbo/obd1 p28 - sometimes injector 3 stops working
hi, My civic 97 ex obd1 p28, sometimes injector 3 stop working. If I turn the car on/off a few times start working again.
Whit this symptom what I have to check?
I hate when people decide what info they want to give and expect people to be able to figure things out. Sounds like something is lose/not make solid contact. Good luck to you.
sorry, for the info. I completely forget it at first.
The ECU send the ground signal, but there's any ground to be checked for injection system malfunction?
Have you check out your main relay? see if the yellow black wire is giving a constant 12v, do check you icm as well ecu pinout a21 and a 22 12v if no wire is loose. and check your fuel pressure if its not under pressure , might be the injector socket. or injector pinout in a5
Good Luck
Good Luck
thatHEMIguy
28
Nov 28, 2010 08:53 PM
THEDirtyDseriesWOOT
Jun 3, 2008 07:42 PM
