94 civic si Ls swap limp mode
Old Jun 11, 2014 | 09:07 PM
Ryan Ballard's Avatar
Default 94 civic si Ls swap limp mode
Limp mode 3500 rpm... Throwing codes... 3,4,41.... I know #4 is cps... But i have tried everything and i am about to give up please help.... Have done everything from new dizzy, to rywire jumper harness and countless ecu's.... Just can't get it out of limp mode.... Any info helps... Thanks...
Old Jun 11, 2014 | 11:33 PM
tony_2018's Avatar
Fish Twig
Default Re: 94 civic si Ls swap limp mode
For an obd1 car why would you need a jumper harness? Have you looked into those cel codes and try to fix them? Is the engine harness jacked up?
Old Jun 11, 2014 | 11:39 PM
McSqueaks's Avatar
Code 41 primary oxygen sensor heater circuit malfunction
Code 3 MAP sensor
Hope this helps
blood843
May 27, 2017 08:50 PM
D Grade
Aug 14, 2016 07:57 PM
lunareg
Mar 3, 2011 01:42 PM
sivik2nr
Jul 17, 2004 07:28 AM
