Overheating problem on fresh turbo build
Old Jun 11, 2014 | 04:55 PM
krazye419's Avatar
Default Overheating problem on fresh turbo build
Well I have a issue and I can't figure it out. I am over heating after a short drive. I went through all the common issues to try and figure it out and still it overheats. I bled the air out through the bleeder valve. Thought it might be the T-stat so I just removed it. It has a brand new water pump and it is circulating. The tune and timing are good. The fan kicks on @ 180 degrees so that works. I'm kind of thinking that the water cooled turbo just won't work on a ZC with a half size radiator? My setup is a DOHC ZC (D16) with a water cooled GT2871R. I ran the coolant line from the bottom of the TB.
Old Jun 11, 2014 | 07:44 PM
redsikiller's Avatar
Default Re: Overheating problem on fresh turbo build
I had a problem like that on my first build.
What bleeder valve are you talking about?
1) Put the front of the car on jackstands with a cold engine, the radiator cap off, and coolant at the minimum bar on the reservoir.
2)Turn the car on and let it run for 10 minutes adding coolant until it is full and barely revving the engine by hand with the throttle valve. Once you see all the air come out and the neck of the radiator get full, put the cap back on and you are done bleeding it.
That's all there is to it.
Old Jun 12, 2014 | 06:43 AM
grumblemarc's Avatar
The Grumpiest
What fan are you using? Stock?
Old Jun 12, 2014 | 08:07 PM
krazye419's Avatar
The ZC's have a air bleeder on the thermostat housing so you can bleed the air out. I also tried your method and it Didn't work so I don't think it's an air issue.
(grumblemarc) I'm using the fan that came with the radiator it has a aluminum shroud
Old Jun 12, 2014 | 08:14 PM
krazye419's Avatar
Picture of radiator and shroud fan
Picture of said setup in my 90 hatch si
Old Jun 12, 2014 | 08:17 PM
krazye419's Avatar
Old Jun 14, 2014 | 07:22 PM
krazye419's Avatar
Anyone?
gunsnbam
Oct 4, 2009 08:07 PM
94c1v1cex
11
Aug 7, 2007 06:56 PM
89_ZC_crx
Mar 12, 2006 08:35 AM
98B18C1
Sep 29, 2005 12:04 PM
fasthatchb18c1
May 22, 2005 09:23 AM
