starter shorting out??? help please!
Old Jun 11, 2014 | 02:02 PM
Jcd5's Avatar
Default starter shorting out??? help please!
basically got my auto to 5 speed done, using a junkyard starter. i forgot to attach the positive, and had everything hooked up and it wouldnt start, so i went to attach the positive on the starter and it started shorting everything out.
with the starter unplugged nothing is shorting, when i attach the starter it shorts, i have the little clip that i assume is negative, as well as the positive cable all attached.
please help time is limited.
Old Jun 11, 2014 | 06:59 PM
slowcivic2k's Avatar
Default Re: starter shorting out??? help please!
.... You should have a service manual beofre performing any repairs.
Just about every vehicle, including 1996 Ford Rangers, use a clip for the S terminal, which is a live power wire. Connecting ground to this point will ruin the wire, and possibly anything attached to it due to over-current.
Big lug = Battery +
Small connector/lug = starter trigger
starter body = Ground
hondachris1994
Aug 15, 2019 03:07 PM
hondachris1994
12
Nov 9, 2017 05:15 PM
twentyhurtz
Dec 14, 2009 12:28 PM
HT Chaplain
Jul 28, 2009 05:33 PM
bayoufrogg
Oct 24, 2006 08:18 PM
