distributor leak
Old Jun 7, 2014 | 04:08 PM
jmanuel's Avatar
Default distributor leak
was taking my cap off. noticed it was leaking pretty good. gasket was pretty much melted and rotor was cracked and broke and the internal shaft seal is leaking.. anyone know where to get another or should iget a new dizzy? 1998 ex v6
Old Jun 7, 2014 | 10:36 PM
holmesnmanny's Avatar
another distributor would come with everything ... try rockauto
Old Jun 8, 2014 | 03:20 PM
jmanuel's Avatar
Default Re: distributor leak
you know how difficult itd be to replace? it seemed pretty straight forward except one step says bring cylinder 1 to top dead center wouldnt know how to do that
Old Jun 8, 2014 | 10:40 PM
Unlike on an obd1 car you don't have to worry about ignition timing. It is three bolts and that's it. Make sure to swap the spark plug wires one at a time so you don't mess up the firing order but it should be pretty straightforward.
Also, the part of the distributor that fits into the head is offset to allow you to only be able to more or less install it one way. So when you insert the new distributor shaft into the head, you will need to line it up. Just look at the new distributor and you will see it is offset so that it's not completely symmetrical. This is so it can only go in one way and not the other way. It will slide in gently if it is going in hard then it is off by 180 degrees.
It looks like the rockauto distributors also come with a distributor oring too.
be sure to google "rockauto coupon code" to find a discount code and enter it during checkout
Old Jun 10, 2014 | 10:55 PM
jmanuel's Avatar
yeah thats what my book says but then the first step on installing is put cylinder 1 on top dead center then insert the distributor? i already have the o ring cause i figured id change it bt then got stuck with that top dead bull haha but yeah my local shop has one for 160? a little better thn dealer price. ihad pulled off all the wires at once so took me a little more time to make sure eerything went were it was suppose to
Old Jun 11, 2014 | 01:23 PM
leflore's Avatar
If there is nothing wrong except replacing internal and external o ring/seal, there is step by step instructions under FAQS. I think I got my internal oring from eBay
Old Jun 11, 2014 | 10:38 PM
jmanuel's Avatar
is there really? ima check that out. isaw a very detailed vid on youtube but havent found any luck finding the seal. dnt trust ebay all too much ihad bought a couple crap off there that bit the dust
Old Jun 11, 2014 | 11:20 PM
Amazon.com: Honda Civic Acura Integra Distributor Seal and O ring 2 Piece KIT OEM Made in Japan: Automotive Amazon.com: Honda Civic Acura Integra Distributor Seal and O ring 2 Piece KIT OEM Made in Japan: Automotive
Keep in mind it won't fit if your distributor is a Hitachi as stated in the auction.
Old Jun 12, 2014 | 12:04 AM
jmanuel's Avatar
my cars a 98 v6 so im pretty sure its hitachi. but i checked out the FAQ on the replacement of it and found a site that says its for a v6 j30a1 hitachi dis for $8! so happy ifound one ijust hope its correct and iwork the courage to do it. doesnt seem to diff jut that top dead center crap scares me ha
Old Jun 12, 2014 | 07:45 AM
mfrs's Avatar
You are not fooling with the timing (position relation of the pistons with the cam) so the worst thing that could happen is it will not start and you will have to move the distributor button position a bit to get it right when you position the top pulley at TDC (See sticky). I repaired my distributor by buying an O-ring from the local Honda dealer and I got the seal from an online store in the US. The bearing had some play so I tried to find one for it but I found that Honda holds the market on that specific size. My seal was for a 97 Accord SE, a part made at KOTEC America Inc. (part# 05-7830-4).
Old Jun 12, 2014 | 10:26 AM
jmanuel's Avatar
i already purchased o ring from dealer and ordered seal from redsautorehab for 8$. so ishould replace bearing to?
and so it should be pretty simple than with no problems i ijust make sure everything is properely put back together and lined up?
Old Jun 12, 2014 | 02:23 PM
The key of the distributor is offset to allow proper alignment into the head when you insert. Just look at it closely and you will see it's not completely symmetrical.
Old Jun 12, 2014 | 05:55 PM
jmanuel's Avatar
alright well ithink ican do it doesnt seem all that difficult hopefully everything goes good.
Old Jun 13, 2014 | 09:04 PM
jmanuel's Avatar
my distributor has a pressed fit pin in it holding the shaft to housing.. you know how ican remove it?? anyone
Old Jun 16, 2014 | 03:09 PM
mfrs's Avatar
If I remember correctly I used a punch and small hammer to tap it out. Keep track how it is disassembled because it goes on properly one way. If you install it 180 degrees out you will find the distributor will not seat properly and you will have to remove it, remove the pin and spin the end 180 degrees.
Old Jun 16, 2014 | 08:13 PM
jmanuel's Avatar
thats what i had tried but had no success after an hour of trying multiple ways to remove pin ijust used a pick to get seal out and cleaned it out and put in new seal and used a deep socket to make sure it was flush and everything was good
Old Mar 28, 2021 | 09:26 AM
Steve O LV's Avatar
I think I’m going to create a video on this for the 6 cylinder. It’s pretty simple, but can be intimidating.
themiz816
Apr 28, 2013 07:16 PM
taguchi09
Jun 11, 2011 04:52 PM
blacktibby07
11
Feb 5, 2011 03:12 PM
cyclonedr
Oct 29, 2010 04:05 PM
blackmfoggie
Jul 26, 2007 02:52 PM
