b18b swap in a 2000 civic
Hey ht doing my first b swap into my 00 ex civic. I have a 95 b18b ls. Got the full swap with axles ecu, shift linkage. Im planning to use my original 5speed civic engine wire harness. I replaced the dizzy plug already and thats all wired up but I had a question about the fuel injectors. The civic EWH doesn't fit the plug of the B18 injectors, and the single cam injectors doesnt fit inside the b18? Which injectors should I be looking for? Thank you
What is EWH?
OBD2 to OBD1 injector adapters. Sounds like you need those. But then again I'm no swap expert.
Older engine in newer car? You know in Cali that's going to automatically fail you when you try to go and BAR it. Is it for daily driving?
Read the following link. Scroll down to the part about injector wiring.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
Oh. EWH=engine wiring Harness.
Capt. Jimbo McSubipants
Apr 16, 2005 11:06 AM
