b18b swap with b16 ecu no 3 & 4 injector!!!!
ok..i have a b18b swap into my Ek...everything was going smoothly until i started it and it bogs alot...i checked the plugs and there fine...checked the injectors..and bingo...no #3 or 4 injectors are working...so...i know the injectors are in working condition...but...i had some obd1 injectors layin around so i wired them in..no avail...then i moved the injectors that i know work into the #3 and 4 slots...still don't work..i am running a obd2a-to obd1 harness..with a b16 ECu i have laying around the garage cause i didn't get one with my swap...wanted to much for the "ls" ecu...so i'm runnin my b16a3 ECU...could that ecu be ****** with it????..
also the harness that i got for this had RC injector clips on it..but i just took a DX harness lined up all the colors and wired them back together...i checked my wiring and there can't be a problem..
only other thing i can think of is...
there are a differnt colored wires for each cylinder..maybe i have the wrong injectors on the cylinders...like #3 injector on the #1 cylinder...i think i have it right...but you never know...or it doesn't even matter...
anyone have the correct colors of the injector wires for each cylinder....
Re: b18b swap with b16 ecu no 3 & 4 injector!!!! (b16delteg)
The colors on your injectors should be like this
Injector1:
yel/blk
Brn
Injector 2
yel/blk
red
injector3
yel/blk
blu
injector 4:
yel/blk
yel
Get it, make sure yel/blk is always the same side The solid colors go straight to the ecu. Check the wiring with a volt meter, and just recheck it again.
Injector1:
yel/blk
Brn
Injector 2
yel/blk
red
injector3
yel/blk
blu
injector 4:
yel/blk
yel
im still looking through my helms but i think that should be it. Another weird sceniro that i see could be that the main relay is about to quit, so you could try swaping it out with a friend.
Re: b18b swap with b16 ecu no 3 & 4 injector!!!! (Luserkid)
uh...another weird senario might be this as well....i was told the harness im runnin is for a 99 cx.....but it plugged into my 97 GSR ecu and my obd2a -obd1 conv harness...so i just came to the conclusion that it was a obd2a harness... worked better in my favor condsidering i'm running a obd2a car...anwyays i checked for voltage and it was higher in the ones working then the ones not working??? could that afffect anything? if that is the case i have obd1 injectos could i wire them in?? and use them..or just 2 of them..or....do i really have a CX harness from a 99 and they too plug into 98's just don't work....i heard they were 1.2.3 instead of plugging 1.2.4..which mine does plug 1.2.4
so i took off my fuel rail and put a new main relay in it...and plugged the injectors into the rail and turned it over...all 4 are working?? ..so....
wtf....seems like it stops workin when i put the rail back on....i dono i'm gonna fill up my tranny with fluid and go for a drive...just runs like **** and makes no sense...
phatboyzef2
26
12-23-2010 12:30 AM
dc2doi
08-24-2009 04:50 PM
fortynineR
08-30-2007 03:08 PM
