older ls engine in newer teg? dirt track racecar
Old Jun 4, 2014 | 05:38 PM
Civic Racer X 7's Avatar
Default older ls engine in newer teg? dirt track racecar
So Im buying this rolling chassis dirt track integra
The guy is currently running a GSR in it and wants to keep the engine
Ive located a B18A1 without a tranny( sure I can find one)
Im pretty sure everything will bolt right in
but Im not sure about the wiring
jumper harness?
can I use this engine with a newer trans?
any complications or any wiring issues?
Not sure if check engine lights really matter although would want 100% performance
whats to do about not having a cat and keeping the CEL off?
http://s30.postimg.org/inp5qp4s1/00_...RK_600x450.jpg
Old Jun 5, 2014 | 07:03 AM
fcm's Avatar
fcm
Old Fart
Default Re: older ls engine in newer teg? dirt track racecar
Integra in link is a G3, [94-up] the B18A1 is from a G2, [90-93] wiring harnesses will be different, ECU will be an OBDI - PR4, or aftermarket.
What wiring is left in the "shell"?
The engine will "drop in" and any B series transmission will bolt to it, and if you get the hydro transmission it will connect up to the G3 no problem. 94
bauer10
Apr 21, 2006 12:37 PM
myDC4rox
Dec 15, 2004 12:23 AM
RACING INTEGRATION
Jun 20, 2004 06:35 PM
bigwave1600
Aug 3, 2001 08:19 AM
