what chemical to clean/remove rust?
Old Jun 4, 2014 | 04:58 AM
Charlie Moua's Avatar
Default what chemical to clean/remove rust?
I had a set of tranmission gears which collected some moisture in the garage and has some noticable rust spots.
How do i remove the surface rust?
Is there a liquid chemical which is effective in removing rust?
Old Jun 4, 2014 | 07:22 AM
fcm's Avatar
fcm
Old Fart
Default Re: what chemical to clean/remove rust?
WD40 and other penetrating oils work, we use MoveIt to clean rust and corrosion. 94
Old Jun 4, 2014 | 10:32 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
I have used Evapo-Rust with great success on many occasions. Although places like Home Depot carry other products that work decent with longer soak times:
http://www.homedepot.com/p/Workshop-...0487/203247483
http://www.theruststore.com/Rust-Rem...art-W22C2.aspx
Old Jun 4, 2014 | 10:44 AM
thanks guys !
Old Jun 7, 2014 | 04:29 PM
OptimisticWay's Avatar
Here are 2 videos on how to use electrolysis to remover rust with a battery charger.
If you can't fit it in the bucket or it is body rust the only way to remove the cancer is surgically, you must cut it out or it WILL metastasize later.
Important note, do not use on stainless steel. A reference to the movie Erin Brockovich is stated in the first movie. The dissociation of chromium from stainless becomes toxic. So, don't do it.
Old Jun 11, 2014 | 10:18 AM
Pro-SeriesFab's Avatar
If its something you aren't worried with keeping the dimensions critical on (like cast parts, do NOT use on ground/finished faces like on a gear) you can use muriatic acid diluted with water.
It will remove rust almost immediately.
big.turbo.daddy
Paint and Body
12
Aug 5, 2015 09:10 PM
LOLYOUMAD
23
Jan 16, 2011 12:49 PM
ozvena
Paint and Body
Aug 18, 2008 03:40 PM
cilvia
26
Feb 7, 2006 06:48 PM
Red88_EF
Mar 17, 2003 08:45 AM
