HELP BROKE VALVE COVER STUD!
Old Jun 3, 2014 | 01:33 PM
thatguy91's Avatar
Icon3 HELP BROKE VALVE COVER STUD!
ok so i over tightened my valve cover nut and the threaded part of the stud snapped so i still have a bit of thread left in my nut just stuck in there. I actually did this twice and i took one of the studs off fine but the other one (middle of valve cover) is stuck so tight the bolt got stripped (10mm) and vice grips wont work they just keep slipping. What do i do to take off the stud every possible option please!
Old Jun 3, 2014 | 01:36 PM
B_Swapped93's Avatar
Default Re: HELP BROKE VALVE COVER STUD!
take the VC off and remove the broken stud 90014-PR3-000 about $7 or can you net even get the but off the stud?.
pics...
Old Jun 3, 2014 | 02:16 PM
thatguy91's Avatar
hey man i got it! i hammered a 3/8 on there and it was tight enough to come off even though it was really stripped now the only problem is to get new studs. My engine is a jdm b18b so do you by any chance know the part number i tried searching and couldn't find anything. Thanks alot!
Old Jun 3, 2014 | 02:45 PM
spoolymcgee's Avatar
liquid wrench.
Old Jun 3, 2014 | 02:52 PM
invest in that^^^ Call honda and get oem replacement bolts. they should have some that works..
liljohn850
Jun 5, 2009 04:23 PM
illmatic118
11
Mar 17, 2009 09:31 AM
butter99
Jan 3, 2009 07:49 PM
integratypeRs
Jan 2, 2009 01:40 PM
Phoenix_ITR
Dec 25, 2002 09:46 PM
