Hot hot is too hot? '93 Accord SE
Old Jun 2, 2014 | 06:17 PM
Roger6017's Avatar
Icon2 Hot hot is too hot? '93 Accord SE
With the heat on while flushing the old coolant out with distilled water today, I noticed the temp on the thermometer I have stuck in the vent reading between 140 and 150 degrees F. That seems very high to me, but the temp gauge on the IP showed the engine temp was cool as a cucumber; steady between the C and half-way mark. I know it was about 90 degrees outside today, but the heat from the vent seemed blistering hot. Should it be this hot from the vent? If not, what might the problem be? I welcome your thoughts.
PS: Long time reader, first time post.
Old Jun 2, 2014 | 06:53 PM
holmesnmanny's Avatar
normal .. the windows raise the temp a lot thats how animals get killed
Old Jun 2, 2014 | 10:53 PM
Roger6017's Avatar
Default Re: Hot hot is too hot? '93 Accord SE
That might initially sound plausable, except the vent temp is still 150 F driving at night with all four windows open. I'm thinking a heater core problem, but I really have now idea at this point.
Old Jun 2, 2014 | 11:03 PM
If the heater control **** is turned to full blue and it's still coming out hot that would suggest the heater control cable is either not connected or broke, especially if there is no tension when you turn the **** indicating it is. You can manually close the heater valve in the engine bay by the firewall by pulling it away from the firewall and see if that gets rid of the heat.
Chuethou_b18c5
Mar 15, 2007 10:46 AM
jdadams12
Feb 12, 2007 07:03 AM
superstud
Oct 14, 2004 12:44 PM
superstud
Mar 14, 2004 08:54 PM
Milton90accord
Oct 10, 2003 04:11 AM
